In my car accident thread, a few people suggested that my car needed its rust protection improved, including inspecting the frame beams. How can a car owner in the United States get their rust protection improved?
I only know of three rust protection systems. Line-X which sprays a coating on truck bed liners but may also work for car undercarriages. In New England, many shops will apply oil or Fluid Film to a car's underside each fall to protect it from winter road salt. The option I was strongly planning to use was the Rhode Island company Auto Rust Technicians, who sandblast and permanently coat the car's underside.
I'm nervous that the sandblasting would damage thin fluid pipes and rubber hoses. Also, the coating might interfere with moving parts, including making nuts and bolts harder to remove.
I plan to replace parts which are rusted if they don't seem to have structural integrity. My first target is the front shocks and struts, though they feel solid. I've been replacing other, simpler parts when I find them (nuts, bolts, brackets).
Honestly, I feel my 2000 V70 has superior rust protection from the factory. It is way better than my 2002 Mercedes-Benz E320 wagon which has rusted through a number of body and structural areas. Is my assessment wrong, such that I need to refresh the rust protection? What company can do this, specifically in New England, USA?
Rust protection improvement
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
FireFox31
- Been thanked: 4071 times
I’ve busted knuckles on 7 Volvo’s Now,and they are the best rust protected brand I’ve worked on.
Fluid film is cool, wcm has it on his car
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
I'd agree fluid film is the way to go.
It won't affect getting stuff off the car when needed. It'll rather make sure you still can by preventing stuff from sticking.
And yes these cars are very well protected already. But eventually it gets through even good protection. My comment in your other thread was mostly a suggestion to make sure it was structurally sound as part of checking if it's possible/worth doing the repair.
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
+1 for fluid film.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- FireFox31
I saw Tectyl mentioned in another forum as a corrosion protection product. Once I get my car in shape, I will consider this for corrosion resistance.
FireFox31
I lied about wcm’s csr, I’ll get him to cough up the product name.abscate wrote: 25 Nov 2019, 17:29 I’ve busted knuckles on 7 Volvo’s Now,and they are the best rust protected brand I’ve worked on.
Aero 303 or something like that?
shegarty
- Year and Model: 1998
- Has thanked: 12 times
- Been thanked: 8 times
Regardless of what rust protection you use (on any vehicle) you need to make sure that you are able to get it into the insides of the frame rails. There are special spray nozzles that some brands market (KBS Coatings have a decent one) that allow access to these and other hard to reach places. You can also make up your own fairly easily with Shop Straws which are basically just longer versions of the little red straws that come on most spray cans. Speaking from lots of experience dealing with rust in Canukistan older Volvo's are by far the best protected vehicles from the factory. If you can get into the hard to reach areas ahead of the salt they should literally last forever.
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
- Rattnalle
Tectyl is just the brand.
You'll want a fluid waxy film closest to the metal and in every little corner of the inside of the car. Then you'll want to cover that with a thicker, usually bitumen based, coat on top everywhere that's exposed to wear from road spray.
- 13 Replies
- 2810 Views
- 1726 Views
Last post by cn90
- 23 Replies
- 3972 Views
Last post by Faust
- 559 Views
Last post by SuperHerman
- 230 Views
Last post by jonesg
