Rearmost exhaust hanger rusted off
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
dlundblad wrote: 11 Aug 2018, 05:06
SuperHerman wrote: 10 Aug 2018, 23:18 The shop that did my XC90 used some rebar - bent it like CN90's pictures and welded it to the exhaust.
Basically all you are doing is bending that shape - dry fit so it fits into the hangers, while supporting the muffler, and then welding it to where the old piece was welded. Once done insert into the hangers - or I suppose you can insert it first and then weld but the heat may melt the hangers.
I'm starting to agree with Oragex's first post on supporting the actual silencer as opposed to it's rearmost pipe since he said it was so heavy.
The wire is ghetto for sure, but it's a quick fix nonetheless.
The wire is located closer to the center of mass, its more effective there than the tailpipe.
Been thanked: 504 times
Post by cn90 »
Looking at the video above, the REARMOST bracket is Skandix PN 1017437, about 14 EUROS.
Does anyone know if you can get this in the USA?
I think FCPEuro should carry this...
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 112 times
Been thanked: 17 times
Post by GlennG2759 »
I recently ordered a P.P.S. Bracket from Advance Auto. It isn't exactly the same as the above bracket as above but for $12.99 and a little modification and it should work for rear muffler tailpipe hanger.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
This UK seller ships overseas https://www.ebay.com/itm/VOLVO-S60-S80- ... XQvtZQ3yQe
(Using this bracket there is a risk the tip of the muffler will break off)
Post by cn90 »
Now I think about it, I will use oragex's ghetto technique bc it is better that way: suspending the muffler body rather than just the tail pipe.
I will use "metal pipe hanger", the same stuff plumbers use to suspend water pipe in the house.
Post by cn90 »
- FCPEuro currently does NOT carry this.
- However IPDUSA just got this back in stock for $9.95/each + shipping. Free shipping if your total purchase > certain $___ amount.
Since this is the only item I ordered, I pay a small shipping charge.
- Have NOT installed it on my 2004 V70 yet, but I know it fits perfectly from posts in the past by others.
- Here is a photo of the PPS...IPD website says this is made in Sweden...
Quality is excellent from what I can tell...
