'04 XC70 -- Snow Tires, Uneven Tread Wear
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
I have a used set of Michelin Ice X winter tires on steelies that I want to put on Ruby Red ('04 XC 70). They were on former owner's XC70. There's probably a 1.5 mm difference in tread depth between front & rear set of wheels. Will that level of discrepancy mess up the Haldex unit?
Deep treads in front or rear -- tire rack suggest rear? Discuss.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 292 times
Been thanked: 765 times
I always put deeper treads on the front, where they wear faster and will "catch up" to the rear. If there is a wear difference now, there won't be one soon.
Otherwise you are unable to rotate directional tires at all, or stuck keeping each set on the same end until the wear imbalance gets out of hand and then forced to buy tires two at a time. When you go to rotate your tires the fronts will by definition be more worn than the rears - the whole argument to keep the deeper tread pair on the rear makes no practical sense unless the difference is huge.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
1,5 mm won't make a difference is my bet.
Front/rear is the same I'd say, small enough difference not to matter too much. Safety is better with best tyres in the rear so the car is less likely to oversteer. But if they're all good that doesn't make as of much of a difference as if you get two new tyres together with two that you're waiting until next year to replace.
Has thanked: 1502 times
Been thanked: 3817 times
Jim is referenced as posting the Volvo spec of 3/32 inch.
So 1/11 of 1inch = 25.4 mm is 2.2mm
If we can confirm the 3/32 spec, you are good. Jim gets this stuff right 99% of the time
E Showell
Post by E Showell »
Ok. Deeper in front to equalize wear.
'95 855 auto (sold)
Georgeandkira
Has thanked: 64 times
Been thanked: 69 times
Post by Georgeandkira »
If misery loves company, that's what I do. ...though I have FWD.
I doubt the educated and urbane visitors to this site would drive in snow to the point where limits of turning geometry would kick in.
Keith Urbane drives Volvo?
Nautic Blue ain’t his colour ?
Rattnalle
Post by Rattnalle »
Georgeandkira wrote: 30 Nov 2019, 07:56 If misery loves company, that's what I do. ...though I have FWD.
It's if you don't drive often in snow these things make the most difference. Those of us who make it a point to go out skidding around in it get more used to it. Next car has to be rwd though..
Rattnalle wrote: 30 Nov 2019, 10:01 ... make it a point to go out skidding around in it get more used to it. ...
So, so true.
'06 S60 R, 197k
Rattnalle
Post by Rattnalle »
Plus it's fun ;-)
