New V70 R-design owner need help
abester45
Year and Model: 2010 V70 R-design
Post by abester45 »
Hello folks. My name is Abe, always had a love for wagons my first was a Saabaru, then Legacy GT, now my first Volvo a 2010 V70 R-design. As soon as i saw one had to have it. Bought the car 2 months ago with 98K miles, has been great until we had a lot of rain and my passenger footwell and rear passenger side footwell became all well. Did some research and read the drain hose in sunroof is culprit. So took some compressed air and cleaned it out best i could and stuck a long wire to push out any debris. Decided to have my local Volvo dealer take a look as well to be safe and on the way there my ABS maintenace light came on. So Volvo folks said for the drain issue the neck and nipple where the water exits is gone and needs to replace those parts and the tube, cost for that $1,533! According to them they have to remove dash to get to these parts which was not mentioned in any of the posts. For the ABS issue they determined a sensor needed to be replaced that controls the belt tensioner, cost for that $900.00! So looking at $2,433 for total damage. I knew Volvos are a bit expensive to work on but $1500 for water drainage parts?? Do these prices sound justifiable? I love this car but there seem like a exorbitant amount can these issues be rectified in a less costly way?
abester45
Post by abester45 »
Anyone?
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
From TBSs Carcomplaints.com
Maybe the water is entering else where? Did they remove some interior trim to look?
https://www.carcomplaints.com/Volvo/V70/2010/tsbs/
STRUCTURE:FRAME AND MEMBERS
TSB #TJ-20698
NHTSA ID #10044280
MAY 29 2012
Additional Info:
How to Fix
Summary: VOLVO: WATER MAY ENTER BULKHEAD AREA FROM RUNNING DOWN WINDSCREEN DUE TO AN INACCURATE ARCH WELDING AND WATER FLUSH NOISE IS AUDIBLE WHEN DRIVING AROUND A CORNER. *PE
MoVolvos
Post by MoVolvos »
abester45 wrote: 06 Nov 2019, 11:11 Did some research and read the drain hose in sunroof is culprit. So took some compressed air and cleaned it out best i could and stuck a long wire to push out any debris.
On my 03 S80 T6 I opened the sunroof and slowly poured water into the drain holes to see if water came out under the car and it did.
shiloh51933
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
abester45 wrote: 06 Nov 2019, 20:54Anyone?
You can fix it yourself but a Volvo dealership charges atleast $135.00 an hour.
The ABS sensor doesn't make sense to me though. For the drainage issues you should remove some of the trim on that side to pull up carpet in front footwell. The get someone to pour water down the drains and watch where its coming from then repair.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
