Issue * came across harvesting a MAf today
The MAf on NA cars are made by DENSO and mount with two M6 (10mm head ) bolts
The bolts are typical steel but bolt into brass threads fused into the air cleaner
I had bad galvanic corrosion on one of mine, so bad the fused and broke the threaded insert ou to the plastic
I had to Dremel it put and re-epoxy the insert into the MAF
Check your cat too, while you test your bolts.
P80 NA DENSO MAF mount bolts issue 1275636
- Has thanked: 311 times
- Been thanked: 817 times
Denso is 99+ cars only. 98 and prior are Bosch, different part.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Your cats appear to be bad, both are missing their precious metals =P
- Has thanked: 987 times
- Been thanked: 1075 times
The cats also look dark - may need cleaning. Might be too rich condition.
(why you always want to logon and see the details and not just the text)
I see you got each cat to face the tail pipe, but now they flow in opposite directions???!!!
Clarifying a bit more
The design is m6 bolt, clearance. Brass boss on air cleaner housing, threaded brass m6 insert in MAF, two pieces.
Look how the bolt corroded in the brass boss, but not in the insert.
Strange. When I went to unscrew this it locked up in both, then broke the insert out of the MAF. It was also locked into the brass boss.
- 1150 Views
Last post by amblerman
- 26 Replies
- 6377 Views
Last post by ChadLee
- 1300 Views
Last post by Nevada1906
- 3290 Views
Last post by Turbo_Boss
- 1337 Views
Last post by vtl
