2001 V70 Oil Leak Back of Engine
- Has thanked: 1511 times
- Been thanked: 3827 times
Re: 2001 V70 Oil Leak Back of Engine
It really doesn't make sense to fix this. With my target for the car life of 200k miles in reach, I think this will go to the next owner is year or two. If you aren't seeing any oil use on the dipstick, clean it once a year like me.
altalake
- Year and Model: 2004 XC70
- Has thanked: 2 times
- Been thanked: 3 times
Good advice. Next major routine maintenance is timing belt and even that's a year away at this rate. Not quite the longevity of my 544s but a lot less rust - and maybe a wee bit safer.
Know its an old post. I am stumped as well. Same place. Was it ever fixed, or a cracked head?
Thanks
96 855t Automatic AC
It seems to under top portion of head.
Thanks
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
95 965 T shift controller in progress
05 xc90 rough idle
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
Did you replace the turbo oil return line and gasket (o ring) ?
I had a heavily oiled engine which magically cleaned up when I replaced that
Oil from that o ring will hit the axle shaft and spray up oil and create seepage looking points I chased for two years
One $5 o ring, dry engine!
The oil is coming from the front of the engine, at firewall
Or passenger side (LHD) again, front
It leaks when hot, indicating seal.
It must be between cylinder heads. Or cam cover
Sorry, should have stated its a 96 850t
So no exhaust vvt
And outside of a crack, maybe the exhaust manifold studs protruding because maybe engine mounts are dyeing
So no exhaust vvt
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
What a wanker I am. Almost two years past “ target life”
Now it’s 300k, 2023.
