IPD sale XeMODeX - Experts in Volvo Electronics Volvo modules repair and programming
Please use the MVS Amazon link when you buy anything at all! It helps this site. Thanks very much!
2011 XC90 3.2, Coil failure followed by p0420 & p0430
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
davido2019
Year and Model: 2011 XC90 3.2
Post by davido2019 »
My XC90 has 211,000mi and currently has the p0420 & p0430 codes set. This problem started when the coil for cyl #2 experienced a meltdown. Three miles from the house I limped home but I know now I should have pulled over and shut the engine down. That week I replaced all coils and spark plugs with new Volvo parts and the vehicle drives fine but these codes will not clear. I have cleared the codes with my scan tool but they both immediately return. Im trying to determine which part(s) have been damaged and need to be replaced. I have the Innova 3040a scan tool and also have VIDA if there are readings I should monitor for clues. Would the main catalytic converter be the most likely damaged part/cause. Regardless of the part(s) damaged i plan to fix and drive this vehicle to 300k and will post the ultimate fix to the problem. Thanks for any assistance.
RickHaleParker
Has thanked: 3 times
Been thanked: 616 times
Re: 2011 XC90 3.2, Coil failure followed by p0420 & p0430
Post by RickHaleParker »
P0420 & P0430 are Catalytic Converter Efficiency. Anything that messes with the Air/Fuel ratio or the burn efficiency can trip them codes.
Did you use OEM coils?
Did you replace the plugs?
Air leaks?
Exhaust leaks
2004 S60R, B8444S TF80 AWD.
davido2019
Thx Rick. Replaced all six coils and six plugs with genuine volvo parts. I will check for intake and exhaust leaks.
Masscomguru
Year and Model: 2008 XC90
Been thanked: 12 times
Post by Masscomguru »
With the bad coil, unburned fuel was just dumping down to the cat. Some distance with highway speeds would burn off any residual gunk. That being said, these codes are supposed to require two drive cycles to trigger the SEL. So if the codes are immediately coming back, they are either not being fully cleared or there are bad o2 sensors. Have you cleared these codes with vida?
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 25 times
Been thanked: 45 times
Post by pgill »
Davido,
Have you replaced your thermostat?
There is some evidence that a failed Thermostat may lead to a coil pack failure.
If you want to understand how the P0420 and P0430 codes are set then take a look at this document
MY07B6324S-S80XC90AWD.pdf
(454.44 KiB) Downloaded 44 times
Also what spark plug part number are you using?
My neighbor was having a catalyst efficiency problem on his Toyota and I fixed with with Denso Iridium TT plugs.
And a friend of mine is running the Denso TT plugs in his 3.2 (with over 200,000 miles) and it is running great no codes.
The stock plugs are Denso Iridium but not the TT (Twin Tip)
Good Luck
Paul
RickHaleParker
pgill wrote: Wed Dec 04, 2019 8:58 am The stock plugs are Denso Iridium but not the TT (Twin Tip)
Denso does not have any ignition parts for the 2011 3.2 per the Denso parts finder..
Bosch has the Double Iridium Pin-To-Pin, Part Number 9615.
pgill
Post by pgill »
RickHaleParker wrote: Wed Dec 04, 2019 4:09 pm
Rick,
You are 100% correct Denso doesn't list spark-plugs for a 2011 or 2012 XC90 3.2
Using the Denso site and looking up the cross reference for the BOSCH 9615 shows the following results
Denso 5344 IKH20 Iridium Power - single fine tip (This is what I use for both of my 3.2's a 2008 and a 2010)
or
Denso 4704 IKH20TT Iridium TT - twin tip (This is what my friend is using and what I will be switching to when I change plugs next)
It is interesting that Denso doesn't list the 5344 or 4704 for the 2011 XC90
For reference Denso does show the following (Iridium Spark-Plugs) for the XC90 3.2
2008 5344 4704 3421
2009 5344 4704 3421
2010 5344 4704 3421
2011 none
2012 none
2013 5344 4704 3426
The interesting thing to note is the switch in 2013 to the 3426
The 3426 is a twin tip Iridium spark plug.
Denso calls it a SIP (super ignition plug)
The gap for the 3426 is .044" which is even larger than the gap for the 4704.
Maybe my next set of spark-plugs will be 3426 instead of 4704
Take care
Paul
oragex
Year and Model: S60 2003
Has thanked: 100 times
Been thanked: 299 times
Post by oragex »
See as above, your thermostat is critical and causes engine overheating on the 3.2 which can also explain a sudden coil failure. If it's the original one, time to swap it. As for the catalytic convertor, 3 miles drive is not that bad - unless the road is going uphill then it can be problematic (always keep some tools and disconnect the injector on that cylinder right away - youtube shows how to locate the cylinder). Don't rush into replacing the cat as yet, even if it was damaged, it may 'recover' after a while, or at least you don't have a Check Engine yet so it's not that bad unless you need to pass emissions.
