Corrupt Canbus, xemodex said good luck Topic is solved
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Now it is time to unplug ETM, then ECM (ETM is "behind" ECM so unplugging ECM also takes ETM out of network), then ABS. You can plug in the ETM and ECM before going to ABS to keep some modules online. One of the modules flatlining that leg of CAN now that the wiring is taken away as cause.
imac
Year and Model: 1999 S80 T6
Post by imac »
Is this with the engine OFF and the key ON? thanks!
imac
Post by imac »
Ok, I hooked my scope up to the high speed bus at the CEM and here are the results:
This was all with the key on II.
I turned the key off between plugging/unplugging, then turned the key back to II, and took a screenshot. Figured out how to use this scope a bit better and captured a longer time sample.
Nothing really jumped out at me as a smoking gun... what do you think?
imac
Post by imac »
I haven't plugged in vida in some time, figured why not. This is what won't clear, as of today.
imac
Post by imac »
The 3rd waveform with the ETM & ABS disconnected is the only one that the ground reference isn't pulled out of whack, but the waveform is junk
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
I would start from replace CEM. This is a main module.
yagger
Post by yagger »
If you have a CEM from same MY car, not need to program it for check signal only.
imac
Post by imac »
I sent my CEM and ECM to xemodex, they said they were both okay!
yagger
Post by yagger »
I trust my eyes only, sorry. Maybe xemodex is good, but I do not trust them. I saw result of them work (DIM repair) and I was confused and upset after that show.
imac
Post by imac »
If these guys couldn't touch it, who can I trust to test my CEM, ECM, TCM, ABS?
I'm in Canada, xemodex is only a couple hours drive and I had read mostly good things on forums about them, but maybe I need a second opinon.
