1998 S70 Cruise Control Turns Off Randomly Topic is solved
ferocity02
Year and Model: 1998 S70 GLT
Been thanked: 14 times
Post by ferocity02 »
My 98 S70 has 197k miles and developed a new issue. When cruising on the highway with cruise control on, sometimes it will turn off randomly as if I were hitting the brake pedal. Sometimes I can turn it back on right away, and other times it won't let me set the cruise control again.
I've tried pulling the brake pedal back with my foot and shifting into neutral and back to drive without any improvement. If it were the vacuum hose under the battery I would think the issue would be permanent instead of intermittent.
Thoughs?
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Search for my prior posts on this topic. I think ultimately I had to replace the cruise control stalk with a good used junkyard unit.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
jvl
Year and Model: 2006 V70 2.4D
Has thanked: 20 times
Been thanked: 8 times
Post by jvl »
This happened to me when the Mass Air Pressure (MAP, not MAF) sensor failed. Cleaning the sensor helped solve the issue.
1999 V70XC - Sold at 250K miles
2006 V70 2.4D - bought at 190k miles and going strong
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
MAP=Manifold absolute pressure
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
ferocity02
Where is the map sensor located?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
My guess would be a failing ABS module.
misha
Post by misha »
ferocity02 wrote: 27 Dec 2018, 08:32 Where is the map sensor located?
N/a 20v cars don't have it...just turbo.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
jvl
Post by jvl »
misha wrote: 27 Dec 2018, 10:11
Thanks Misha for adding that, you just taught me something, too!
ferocity02
UPDATE: Issue was solved by replacing the cruise control relay.
I replaced the cruise control stalk at the time time but tested the old one thoroughly and it seems to work flawlessly even when shaking and rattling it around.
