Where you been typeing your messsages is the standard editor. Full editor is a editor mode that has more options, including file attachments. look below I marked the button to get into the Full editor. Full editor is more like a word processor.
Her first CEL
- RickHaleParker
- Been thanked: 979 times
Active
Past
Past
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
More fun with lights and codes. When I just had the CEL cleared there was another code: No DTC definition found. Consult service manual.
The CEL has stayed off so far.
Also I have noticed that when I punch it enough to engage the turbo, the ABS light comes on. Only time that light comes on.
I think that's it.......for now
Mucho Gracias !
Mucho Gracias !
1999 V70 GLT
1999 V70 GLT
- RickHaleParker
The P80s are notorious for cracked solder joints at the ABS connector.Sveedy wrote: 14 Dec 2019, 10:36 Also I have noticed that when I punch it enough to engage the turbo, the ABS light comes on. Only time that light comes on.
I an thinking:
When you step down the engine torque moves the ABS harness, opening solder cracks on the PC board at the ABS connector.
Active
Past
Past
- Sveedy
Yes Rick that sounds about right. I noticed that it seems to have more to do with the sudden movement, either by the turbo kicking in or the tranny down shifting. I think I saw a post about having the ABS module repaired but I'm not sure.
1999 V70 GLT
1999 V70 GLT
- Sveedy
Neat ! Thanks ! I guess there goes another $ 100 + but if it solves the problem it's a deal
1999 V70 GLT
1999 V70 GLT
- Sveedy
Just wanted to say " Thanks for everybody responses ! ". I've been on other forums where you feel like your alone in a field of crickets.
I would " Thank " formally so it would go to your signatures but guess what ? I can't figure that bit out either
Truly appreciate all your help,
Paul
Paul
1999 V70 GLT
1999 V70 GLT
Sveedy wrote: 15 Dec 2019, 07:48 Just wanted to say " Thanks for everybody responses ! ". I've been on other forums where you feel like your alone in a field of crickets.
Paul
- 29 Replies
- 6824 Views
Last post by wizechatmgr
- 573 Views
- 699 Views
Last post by shiloh51933
- 1388 Views
Last post by oragex
- 51 Replies
- 8077 Views
Last post by ZionXIX
