Is that the edge of the valve? Exhaust side?
I want to get myself one of these mini scopes!
Help getting 1997 850R back road worthy
- Has thanked: 987 times
- Been thanked: 1076 times
Empigt
- Year and Model: 1997 850R
- Been thanked: 2 times
Yes that is an exhaust valve
Looking for exhaust valves now. I see these came with sodium filled valves. Not seeing any oe replacements. Who makes a quality stainless valves with hardened surfaces?
Empigt
So looking I can't find sodium filled valves. Will the valves in the 99 v70 turbo head fit? I hate to put used valves in. But if I can't find any. I may have to. I would like to do all 10 exhaust valves so they would be even in age.
Empigt
Also I read to get only a volvo head gasket. But others say Victor rienz is the same. Any other thoughts on the best set. Fel-pro, elwis?
Hoping to do all this next weekend but need to get everything coming and here before then. Supposed to be warmer and working outside without heat is no fun. So need to get valves and gaskets on there way by tomorrow. I located used original valves. Going to by a full set of 10 and save my good ones for spares. And do my own head rebuild. Seals and valve job. Any help appreciated!
- Been thanked: 4071 times
The stem sizes changed in 1999
You do want the sodium filled valves in a turbo to carry away the extra heat produced
I would go Volvo from a dealer or at least FCP for the head gasket. That’s a lot of work to redo if you use an unknown part
Victor Rein and Felpro are well respected makers, but it’s the supply chain you worry about here
- 9 Replies
- 1916 Views
- 150 Views
Last post by volvolugnut
- 1630 Views
- 1288 Views
Last post by uncledave11
- 2019 Views
Last post by Krons
