ECM location or how to turn off check engine light
1996 - 2004 S40
1996 - 2004 V40
25patches
Year and Model: 2003 volvo s40 1.9lt
Post by 25patches »
Got the code P0015 and ordered the parts; the cam shaft position sensor, crank shaft position sensor, V V T. While waiting for the parts, disconnected the battery-positive and negative-for 4 days. Put in the parts and the check engine light is still on. Have read that removing the ECM will turn off the check engine light but haven't been able to get a schematic of where the ECM is for the Volvo s40 2003 turbo 1.9 Lt. Does anyone have a better idea of how to reset the check engine light or turn it off so I can see if I have solved the problem with my Volvo. Any suggestions :?:
Patches 25
alschnertz
Year and Model: 1995 854T
Has thanked: 2 times
Been thanked: 12 times
Post by alschnertz »
What type of scan/reset tool are you using?
I once had a stubborn CEL and ultimately had to reset the ECU with help from the scan tool (ScanGauge II) manufacturer.
All was good afterward.
'84 Prelude
'06 MPV
'13 Ford Focus SE
