Left side mirror keeps moving won't adjust by control any suggestions?
I bought spare at scrap yard from different model I'm hopping I can rebuild it anyone who can advise please make comments.
Happy Holidays
Regards Bobby
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
After sorting the passenger heated seat the other day I decided to look at the drivers one. The heated seat was working but would get very hot indeed - leading me to suspect the thermostat wires again. I guess in this instance because both wires were broken/disconnected it allowed the heated seat to work, unlike the passenger side with one wire intact. I was lucky in that one wire still had a length of cable attached to the pin, so I could just solder the broken wire back together again. The second broken wire required a new pin to be crimped, just like the passenger side from a few days ago.
A shot of the solder sleeves I've been using for broken wires. Make life very easy indeed, especially for automotive purposes or where access is tricky with a soldering iron!
- Has thanked: 987 times
- Been thanked: 1075 times
Well, I have learned something today. I did not know about solder sleeves. I think I need to upgrade from crimp connectors, which are prone to corrosion.
- Has thanked: 316 times
- Been thanked: 531 times
Little more progress on the manual swap today... pedals and master went in last night and the shifter and cables went in today.
Had some "scheduling issues" and nasty rainy weather yesterday that put a damper on things, but tomorrow will be nice again and hopefully we can finally wrap this up! It's already taken WAY too long.
We also pressed in some delrin subframe bushings... really easy to knock right in with a dead blow! The old bushings came out surprisingly easily too... just cut through the outer shell with a sawzall and knocked them right out with a screwdriver and hammer. I tried to use the press, but the subframe is pretty heavy and I couldn't get to a saw horse to hold it up, and the angle on the front part of the SF wouldn't allow it to sit evenly to make the press effective.
So how do those work, just use a heat gun/lighter? That's a neat concept!Cookeh wrote: 18 Dec 2019, 14:40 A shot of the solder sleeves I've been using for broken wires. Make life very easy indeed, especially for automotive purposes or where access is tricky with a soldering iron!
- Cookeh
They are a joy to use. Crimp connectors are supposedly slightly better from a resistance pov, but we're talking tenths of a single percent to one point difference typically. Crimps can be made fully waterproof and more resistant to corrosion when used in conjunction with adhesive lined heatshrink, though.volvolugnut wrote: 18 Dec 2019, 18:41 Well, I have learned something today. I did not know about solder sleeves. I think I need to upgrade from crimp connectors, which are prone to corrosion.
Exactly that, just slide over one side of the wire, mechanically join the wires (lineman best option as with anything), slide the solder ring in the sleeve over the join and then use a heat gun to melt both the solder ring and the adhesive rings. Lighter won't work here as it won't get hot enough to melt the solder ring without either burning the heatshrink of blackening everything!bmdubya1198 wrote: 18 Dec 2019, 22:17So how do those work, just use a heat gun/lighter? That's a neat concept!
Yeah, I've never understood how people use lights for heat shrink... I've tried it and just burned it!Cookeh wrote: 19 Dec 2019, 01:35
I'll have to find some of those though!
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
I've used a lighter with decent results. Just have to keep it moving to spread the heat evenly. Heatgun of course works much better.bmdubya1198 wrote: 19 Dec 2019, 08:07
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 112 times
Replaced my lower passenger side engine mount (Febi) and transmission torque mount (Hutchinson)
Can definitely feel the difference, the engine isn't rocking around at every gear change and the car is quieter at idle.
Replaced the leaking radiator with a Nissen and the intercooler with a cheapo chinese one
Getting it back in was a bit tricky since the new intercooler is quite thicker. Everything works but I'll have to tidy up some things tomorrow.
Also replaced the broken tweeter in the dash and the d pillar speakers. One isn't working, I'll do more troubleshooting but I'm suspecting a wiring issue. Getting close to a fully working audio ( getting the dolby speaker to work will be the last part)
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Finally got most of the air to burp out of the cooling system (took over a week) after replacing half of the hoses. Went to pull the cap off and top up the coolant, and was surprised to hear air hissing. First time in 3 years the cooling system has held pressure for more than an hour (car was parked for 2 days).
Really need to get it together for this clutch and RMS job. Guy at the alignment shop just complimented on how low the clutch grabbed. Thought he was crazy, especially when I almost couldn't get started from the stop sign on the hill. The screeching is starting to haunt my dreams.
Knows enough to be dangerous
Just wrapped up my cousin's manual swap last night. Took it for a few drives around my neighborhood and it runs and drives great! Just waiting on the manual swap tune from Hilton and it'll be good to go. We're also going to bleed the clutch again today as well as the brakes just for good measure, and it should be done.
