Corrupt Canbus, xemodex said good luck Topic is solved
imac
Year and Model: 1999 S80 T6
Post by imac »
I've found a MY2000 s80 t6 that I am going to drag home today and start swapping modules between the two cars. I'll be swaping everything on the HI speed loop
CEM
TCM
ECM
ABS
and ETM if required.
Can anyone offer any insight into what modules are VIN locked and will also need to make the journey from the 2000 to the 1999? I'm aware there may be issues with with the key/immobilizer and will swap the ignition key if required.
Thanks! I'm so fed up with the BRAKE FAIL nonsense. Game on!
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
There is configuration file in the CEM, if there are some differentials between your CEMs some your original options can stop to work.
ETM should be installed with ECM together, like a pair.
imac
Post by imac »
Damn, the ETM has to go with the rest eh? Normally i'd be all over it- no question about swapping every last module HI and LO, but..... its mid december in Canada!
I got the donor car home, I'll start pulling modules shortly. As much as I don't want to swap every single module on account of the weather (garage is full with a project car, not my daily driver lol) I'm worried that a single failed module could have caused all of my troubles here, and if I get lazy and don't swap everything I may be right back where I started. I should probably change the seats to match the power seat module to the cem, and door modules, uem, etc.
Good times
imac
Post by imac »
Here goes nothing...
I pulled the CEM, TCM, ECM, ABS, ETM, DDM, PDM, PSM, ISM, SWM, UEM, REM, SRS, DIM, and CCM from my donor s80,
Along with the seats as the psm is there and my driver's sips was an error that wouldn't clear in vida.
These are going in my car tonight, wish me luck :)
Been thanked: 4065 times
Hereafter to be referred to as the FOT
Full
Organ
Transplant
You could do MVS a great service by swapping in some order and documenting what really is VIN coded.
GLWS!
Good luck with SWAP!
:D :D :D
imac
Post by imac »
FUCK YEAHHHHHH!!!!!!!!!!
She's alive.
Updates to follow with some pics and advice, but for now: SUCCESS!!!
Cheers all, time for a beers :)
yagger
Post by yagger »
What about VIN? It is in the CEM. How are you going to get smog check permission?
Ou, I forgot, you are from Canada, possible other rules there.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Just tell the inspectors that your car is in the witness protection program and has been issued a new identity.
yagger
Post by yagger »
Check your Atacama interior cars coming into Canada for persons running from peach infestations - apparently the bone spur defense isn't working anymore. They will try to blend into the orange interior.
