Oil pan gasket replacement
Been thanked: 504 times
Post by cn90 »
At 193K km, it is still midlife...
You have a long way to go.
Best is to find a similar car (2.4, 2.5T) with lower mileage and listen to it.
A bit of tapping noise is normal for the Volvo 5-cyl engine.
Or listen to some youtube videos to find out what "normal engine noise" is.
Both my 2004 V70 2.5T and 2005 XC90 2.5T have similar tapping noise.
PS: Best is to use synthetic oil, change it at short interval such as 2500-3000 miles for a few cycles, based on the assumption that the P.O. did long oil intervals and that there is some sludge in the engine.
Dmarks
Year and Model: 2002 s60
Post by Dmarks »
Okay, ill give her an oil change. I heard they are picky about what oil filter is used. Whats the best one to get? Im pretty mechanically inclined (have owned 3 saabs) and i did all the maintenance myself. Just new to volvo as this is my first one
- Pete -
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
I’ve never tried on MVS, but you can upload to YouTube, image shack or photobucket etc & post here.
Mahle or Mann filters.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
Supergrunged
Year and Model: 2005 S60R
Has thanked: 3 times
Been thanked: 4 times
Post by Supergrunged »
Tick is normal for a Volvo. Especially when the Oil is a quart low. Just the valves up top tapping every now and then.
Fix your intake leaks, and clean the throttle body. Common a dirty throttle body shows a code on these cars. Your codes are showing something along those lines, as the throttle body measures air across the plate as well. The ECM uses this, and the MAF along with the boost pressure sensor to monitor the air coming in.
Dmarks
Post by Dmarks »
Hey guys so i uploaded a video on youtube, here is the link let me know what you guys think
Post by cn90 »
- That ticking sounds like my 2004 V70 2.5T with 110K miles...
- Oil: synthetic oil you can find in Canada.
- Oil Filter: I use Mahle.
- Tool: you need this otherwise you will strip the oil filter cap.
Best is to get new filter cap every 100K.
https://www.amazon.com/Assenmacher-Spec ... B000XML6DU
Dmarks
Post by Dmarks »
So the ticking im hearing is a normal thing with volvo motors?
- Pete -
Post by - Pete - »
I’m guessing that was with a warm engine.
Sounds fine to me.
Given your location I’m guessing it’s cold enough. On a cold engine a knock is pretty easy to hear. Sometimes warm, under no load & idling it can be very faint.
I have a clip of a knocking 06 idling if you want to hear it. The engine had only been knocking for approx 10 minutes, according to the owner who supposedly caught it early & stopped driving it.
I didn’t have my stethoscope with me, but oddly enough it sounded like cylinder #3. Typically you’d expect #5 if sludged or a low/no oil psi condition had occurred. Probably just the sound reverberating in the intake manifold “ball”.
Edit: As you can see, the knock sensors had picked up this knock & generated a code. I think the microphone picked it up pretty well also. I have another clip I can post if you’d like.
You can tell it’s still idling higher than a warm engine. I think idle steps down two times after cold startup. This is the first step down from the initial high/cold idle.
IMG_6190.MOV
(20.21 MiB) Downloaded 222 times
Edit:
Uploaded .mov file to YouTube.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- Pete -
Post by - Pete - »
Sorry, don’t mean to domineer. I think this may be of importance. This is the same engine, just later in the warmup cycle. Notice how much the knocks pervasiveness has subsided once the engines idle speed has settled down.
I hadn’t realized how almost imperceptible the knock was on camera until I rewatched this video I took a couple months ago. In person I feel it is much easier to detect after the engines idle speed has stabilized.
IMG_6191.MOV
(28.59 MiB) Downloaded 121 times
Edit:
For those who can’t view .mov files,
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
Dmarks
Post by Dmarks »
No the video i posted was of my engine cold, it was only running for about 2 or 3 mins. Im unable to open your videos. Does mine sound like a knock 😳
