removal of sepentine belt 2009 s60
volvomadness
Year and Model: v70 2003
Been thanked: 9 times
Post by volvomadness »
Trying to removal the serpentine belt of 2009 s60. I have done these on 2005 and lower but not on a 2009. Don't see where to put the tool in for the tensioner, Is there a plastic cover on the tensioner?
If so how do it get the cover off
Thanks Madness
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
It can be either torx hole or the hex nut on the bearing. I've had both types of tensioners.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
If there's a black plastic cover, put against its side a long flat screw driver then give it a small smack with your fist (I've simply used a long piece of pipe), it should jump off & no need to put it back. If you're going for the hex bolt, you need a ratchet slim enough to fit by the car frame. For the tension, you'll need a long handle, an extendable ratchet is the best - also toss the power steering reservoir - if you also lift the coolant reservoir, undo first the electrical connector underneath or it may damage the level sensor
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
OR
Active
Past
