Hello,
Can someone please help me determine where the starter is located on a 2009 S80 T6 engine. I'm attaching a pic of the engine.
Thanks a bunch!
Starter location on an S80 T6 3.2 L Topic is solved
petera58
- Year and Model: 2009 S80 T6
- Has thanked: 3 times
Yes, I took my old starter out to test it because I had replaced the battery on my vehicle and it wouldn't even turn over. I tested the starter with a direct hook up to my battery and a multi-meter and I was getting 12.5 volts to it but it wouldn't move at all.
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
The Land Rover LR2 was based on the Volvo S80 when it was designed.
I own the LR2 and S80
A LR2 link that shows the starting circuit
Note: the S80 has a different configuration but I suspect that it has the same components
Look at the picture in this link. https://www.freel2.com/forum/topic33546-15.html
The key things that would prevent the starter from turning
- Fusable link by battery + connection
- Starter relay (sends power to the starter solenoid)
- Fuse for starter relay
- broken starter (worn out brushes)
Good luck
Paul
Good luck
Paul
- pgill
That is a very unique failure.petera58 wrote: 27 Jan 2020, 12:59 So it turns out my AC compressor is seized up and that was preventing the engine from turning over.
I've read about clutch pack failures for the AC and the compressor on my S80 lost its ability to cool the car.
But I've never hear about the compressor seizing and the pulley seizing (or clutch staying engaged) and then the engine won't start.
I am glad to hear that you found the source of the problem.
Thanks for sharing
Paul
petera58
Thanks for all your help!
Now the fun really begins - changing out the ac compressor. My car is actually an 09 Volvo S80 T6 Sedan 4-Door 3.0L. I sent away for a repair manual from ebay that I'm hoping gives me details because I can't quite find the process for my engine on youtube or elsewhere. If those manuals work, I'll let folks know.
- 24 Replies
- 8617 Views
Last post by MrAl
- 1311 Views
Last post by rw06
- 1565 Views
Last post by yagger
- 947 Views
Last post by SuperHerman
- 1611 Views
Last post by asap11
