Hi all,
I just tried to fill my gas tank and it kept shutting the pump off after about 3-4 seconds of pumping. I haven't filled the car in a couple weeks as i recently had the car out of service taking the whole engine apart and putting it back together.
Probably more importantly, yesterday I pulled and replaced this broken portion of hose behind my fuel filter. Both sides of this hose looked like this. Any chance that this could've causes this?
Reading about others' problems it seems like people's carbon canisters get blocked and don't allow enough air out. Im assuming that's what this black box is, has anyone else ever had to clear this out?
Gas pump shutting off before tank full - 99 s70 na
- Been thanked: 4063 times
That’s the canister shut off valve with the broken hose. It might be broken on the air side which won’t affect much. The rectangular black box is the carbon canister
Your fuel tank issue is caused by a bad head gasket, though.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
There’s a small opening on the bottom of the filler
spout that detects fuel when it gets high enough
and automatically releases the handle latch.
Sometimes, pulling the nozzle back out of the
car’s filler neck just a little will prevent this feature
from shutting off the fuel pump’s valve prematurely.
Generally, just one nozzle spring “notch” will do.
- 800artfreed
- Year and Model: 98 S70T5; 99 S70GLt
- Been thanked: 26 times
Abscate did you really mean a bad head gasket? Don't fuel fill issues relate to the EVAP system and venting the tank when filling?
Thanks.
Thanks.
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
I was taking a terribly mean shot at Smacnab who just completed his heAd gasket job yesterday
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
I'd like to report harassment but I don't know who moderates the moderators lololabscate wrote: 26 Dec 2019, 21:41 I was taking a terribly mean shot at Smacnab who just completed his heAd gasket job yesterday
Thanks for the tips everyone, I'll check that filler filter today!
07 V50 T5 AWD M66 ~146k miles
bronco
- Year and Model: 1998 V70
- Has thanked: 49 times
- Been thanked: 24 times
it seems like you needed to set this up a little more, it probably sailed over everyone's heads
Be Better!
#moderatorsmackdown
- 1377 Views
Last post by AKJeeper
- 9 Replies
- 2094 Views
Last post by theWIFES_S70
- 2998 Views
Last post by Clemens
- 350 Views
- 1409 Views
