getting ready to R&R the driver's side CV shaft
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
Looks to be an easy job, except for pulling the shaft out of the transmission. Most vids talk about how that can be difficult due to a stuck snap ring. It's hard to see in the vids but is there enough room and access to get some snap ring piers up in there to release the ring?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- SuperHerman
- Been thanked: 207 times
No - the snap ring is internal. You need to pull it sharply or rap it sharply and it will compress and pull out. A slow pull will not work (maybe with a special tool) - you also need to exert force on the outside of the inner portion - not pulling on the shaft as the joint will absorb the energy. Last time I did mine I think I used a larger flat (flat head screw driver or crow bar), found a place to place it and gave it a good wack with a hammer. Just place it some where it will not chip anything.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The Volvo spare tire wrench has a flat end which fits nicely to pry on it. May have to remove the splashield if you still have it
Also can get stuck inside the wheel hub (hopefully not). I once tried to remove one at the junkyard - it was so stuck inside the tranmission, I broke the tip of the spare wrench, a cold chisel, then brought a 2ft pry bar - no luck. When installing a new one, if the clip is too large and it doesn't slide in easily inside the transmission, don't force : it may never come out again. Also may use some grease both on the transmission and spindle side.
azureblue
thanks. I have an aftermarket spare tire tool. The original was a stamped lug nut socket that screwed onto the tow eye. I have a few pry bars - one looks like a huge long screwdriver with an angled tip and i have one of those pry tools use to pull nails out of wood. and a huge crow bar. one of those has got to get it out . I have been working on my French profanity bout maybe I should pick up on some Swedish before I get to prying on this thing..
I may go to the parts yard and practice before I go to work on mine.
so if the clip is too large, is it ok to swap it with the old one?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
Great idea to practice on junk first.
When I removed the transmission on our V70 AWD I used a pair of claw hammers. I’d spin the half shaft 1/8 turn, pry, 1/8 turn, pry, 1/8 turn pry etc. I spose a good method would be with two people, one person with the claw hammers & the other with a hammer & brass drift.
I never like prying against a trans housing but there’s not enough room for the tool I usually use with a slide hammer, so just gotta grit your teeth & go for it.
Check your trousers, trans housing, & if all is well enjoy the rest of the task.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- Been thanked: 504 times
I learned the trick from jimmy57, basically the C-Clip in the axle has an opened end.
You want the opened end to face down so it does not "hang" and gets stuck.
So rotate the axle, pull a bit, rotate again, no need to force it.
I posted all the tricks in the DIY in this forum...
azureblue
I thought the C clip was a snap ring, hence the question about getting snap ring pliers in the to compress the C / snap ring.
Yeah, I'm concerned about prying against the transmission housing. That sounds scary. I was hoping to put something against the transmission housing the spread the pressure. Or maybe pry from opposite sides at the same time.
I'll go looking in the DIY forum - thanks
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Don’t over- worry this. I’ve never spent more than 73 seconds popping an axle
If you get stuck, come back here
NOTE: I used a small piece of cardboard folded in half as cushion, then cold chisel in between the cardboard.
The gently chisel between the INNER CV joint and the Trans Housing: the axle came out w/o issues.
Here is the DIY.
DIY: 2004 V70 2.5T Volvo Axle and Seals (110K miles)
viewtopic.php?f=9&t=91594
Here is the DIY.
- 11 Replies
- 2661 Views
Last post by bronco
- 5196 Views
Last post by SuperHerman
- 663 Views
Last post by erikv11
- 9 Replies
- 5212 Views
Last post by huzzsaba
- 19 Replies
- 4972 Views
