Reverse parking sensors
heated
Year and Model: 2003 V70 2.4T
Post by heated »
New to my family is a green V70 2.5T, on the rear of the car is what seems to be parking sensors. The previous owner was very vague with everything that was said and I took it as is. Because all the small faults like the door handle not opening, lights and dents I could fix. The parking sensors don't work but I've looked for where it would link into but I'm not sure. Some of the parts have been professionally repainted to make the car look whole. By the previous owner, I'm not quite sure what models or years came with that feature or if it was just added in. I'm also experiencing high idles far past the normal rpm when I start the car. Could it also be the throttle body going out?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
At cold start up the idle goes to 1700rpm for 30 sec to heat up the cat converter and prime the brake booster. Parking sensor was quite rare option, perhaps only needs a used sensor, maybe off Ebay ?
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
heated wrote: 01 Jan 2020, 14:57 The parking sensors don't work but I've looked for where it would link into but I'm not sure.
Is the LED in the Park Assist switch on?
Active
Past
heated
Post by heated »
Not quite sure where that would be on the dash. Am I allowed to post imgur links?
RickHaleParker
heated wrote: 02 Jan 2020, 13:39 Not quite sure where that would be on the dash. Am I allowed to post imgur links?
It would be in the row of switches in the center console.
Park Assist is an option not standard equipment.
Active
Past
Has thanked: 1609 times
Been thanked: 4065 times
It’s standard on all P2s
If you have the switch, it goes “ beep”
If you don’t , it’s single “ crunch”
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
abscate wrote: 03 Jan 2020, 04:23 It’s standard on all P2s
:lol: Typical abscate wisdom here.
When this feature is turned on, the radio display will say: "park assist aktive"
I thought at first that this is a gimmick, but I have come to appreciate it a lot and use it all the time.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
