Vida Dice Findings
- subzerocarfanatic
- Year and Model: 2000 Volvo C70 HT
- Has thanked: 75 times
- Been thanked: 10 times
Can anyone maybe help shine light on some info on my findings with Dice tool. Here is an image for starters.The accelerator pedal is a fairly new OEM Volvo that was replaced before i bought the car. My ETM seems to past the test so i can now remove that from the equation of it being the culprit.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Read & erase the codes and see which ones comes back.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- subzerocarfanatic
The codes are current.
- misha
In that case i would check the wiring and connectors.
Is the car in question 2000 C70?
As far as i know if you replace etm on '99+ cars...it needs to be programmed in order to work,because they are "married" with the car.
I could be wrong,so i would wait abscate or someone with '99+ car to chime in.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- subzerocarfanatic
According to the ETM test done with VIDA DICE it passed the ETM test, both potentiometers were in sync with one another, if there was a way to share the short video recording i made while running the graph test i would put it on here to share my results.
- Year and Model: Many Volvos
- Been thanked: 76 times
I would snag a accelerator pedal assembly from a junk yard if you can find one. That seems to be VIDAs biggest complaint.
I don't think the pedal sensor has to be married in software to the car but I could be wrong, I have swapped ETMs between cars and left the original pedal sensor there.
Neither Pedal sensor nor ETM are married to VIN but ETM must match software in ECM
If you pseudo- randomly swap an ETM from Magneti Marrelli, it’s roughly a 20% chance of working
- subzerocarfanatic
It has a practically a w pedal assembly, an OEM Volvo one, the guy i bought the car from said he just spent around $200 for it and installed it right before i bought the car. But something is clearly not working properlyOzark Lee wrote: 05 Jan 2020, 14:59 I would snag a accelerator pedal assembly from a junk yard if you can find one. That seems to be VIDAs biggest complaint.
- subzerocarfanatic
How can i find out what software the ECM has because i saw everything in the vida test about the ETM, software number and everything and it says software was up to date i believe.abscate wrote: 05 Jan 2020, 19:08 Neither Pedal sensor nor ETM are married to VIN but ETM must match software in ECM
- 29 Replies
- 5427 Views
Last post by WhatAmIDoing
- 16108 Views
Last post by xiaofei204716
- 10 Replies
- 18924 Views
Last post by jonesg
- 7047 Views
Last post by Klem
- 10151 Views
Last post by jonesg
