2006 Volvo S60 2.5t code p0089
rjj100
- Year and Model: 2007 S60 2.5T
Try it again with the engine running, but wear eye protection, have a fire extinguisher on hand, and cover the schraeder valve with a thin rag with the cap on the schraeder valve off. Then push the pin in the middle of the valve thru the rag. Be prepared for a high pressure spray of gas.
Or, you could just trust the mechanics gauge which said you had 60 psi.
Let us know when you have checked the wiring to the fuel pressure sensor and replaced the sensor.
cbpitt01
- Year and Model: 2006 V70 2.5T
- Has thanked: 6 times
- Been thanked: 4 times
ima, wat, dat, u, lil, wen...
For God’s sake, PLEASE use actual words - like the moderator has already requested you do. Users of this forum are more likely to take you seriously and offer advice when you follow the posting rules.
2006 V70 2.5T, Ice White with Arena/Oak, bought “newsed” @ 183,500 miles in Dec 2015; 244,000+ as of 12/23/2020.
All posters are thanked for following our requirements for complete sentences and punctuation.
If posting from a phone inhibits your ability to do this, please refrain from posting until you can access a keyboard portal to the internet, or call a friend with such access so s/he can input accordingly.
Pat007
- Year and Model: 2006 s60 2.5t
Sorry it took me so long to reply but I changed the fuel pressure sensor and it still running funny .it’s like when I try to mash the gas it don’t take off for real I have to lightly mash the gas for it can go.I change the spark plus,coils packs,fuel pressure sensor.mass air flow sensor ,fuel filter, and i also bought a fuel pump and someone told me is Bold but my fuel pump kick out 60 pbi and it supposed to be 43 I think but its still not running right I have a video of what it doing since I put the fuel pressure sensor can someone help me figure this out I have a video but when I try to upload it it say it’s to large
- RickHaleParker
- Been thanked: 978 times
60 PSI is about right.
Fuel line pressure desired value
Relative pressure 380 kPa ( 55 PSI )
Absolute pressure 480 kPa ( 69 PSI )
Active
Past
Past
Pat007
I have a video what you can see what it doing but I can’t upload it here.but when I try to mash the gas it shall and make a roaring noise I have to slightly smash the gas for it can go you know what it can be?
You can upload to youtube , then use the YouTube tags in full editor to link the video here.
- RickHaleParker
The YouTube tag is gone there is a media tag that does the same thing, it might work for all media. The insert media tag is an icon that look like a display screen.abscate wrote: 04 Jan 2020, 09:28 You can upload to youtube , then use the YouTube tags in full editor to link the video here.
Active
Past
Past
- 1452 Views
Last post by SHOCKWAVE
- 2472 Views
Last post by bfry
- 590 Views
Last post by cn90
- 4596 Views
Last post by stickman776
- 1618 Views
