P2122 codes
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
When the Serp belt snapped is there any way it could have damaged the back or bottom side of the ECM/TCM box and, more specifically, the connections on the bottom of the modules?
Ftknox1301
Year and Model: 2002 XC70
Post by Ftknox1301 »
So now I got a new problem, I tried removing the ECM and TCM so I could inspect them to make sure that everything looked in its place and now after reinstalling them the car will not start. Getting a p0727 and p2121 code now. Car will crank but will not start.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
P0727 is no crankshaft position sensor. Now it really looks like a wiring problem.
chrism
Post by chrism »
Ftknox1301 wrote: 07 Jan 2020, 11:26 So now I got a new problem, I tried removing the ECM and TCM so I could inspect them to make sure that everything looked in its place and now after reinstalling them the car will not start. Getting a p0727 and p2121 code now. Car will crank but will not start.
Did you use the lock/unlock tool to get the pink sliders latched back into the locked position? It’s the sliders that pull the modules snuggly down into the connectors.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Did you clean the connector before you reinstalled the ECM and TCM?
Sometimes oxidation will prevent a good connection and produce errors that did not exist before the control units where pulled.
Active
Past
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Your vehicle appears to be outfitted with the MM throttle body. Known to cause all sorts of issues and subject to a recall if I recall correctly.
It looks like you have eliminated the free stuff - now it is time to focus on the throttle body. But RickHaleParker's suggestion to check all the connections and clean them is valid. These cars are getting old and a poor connection could cause your issues.
VIDA has the ability to check the throttle body operation is as do some other higher end scanners.
