Vida 2014D Times out 12/31/2017 23:59 Topic is solved
rjj100
Year and Model: 2007 S60 2.5T
Post by rjj100 »
I believe I had IE11 installed at the time I ran the scripts the first time, and removed it when I configured Vida Chrome.
It is enabled now and I will try rerunning the scripts per your recommendation.
I did notice I have Hyper-V Virtual Ethernet Adapter, in addition to the Wireless-N WLAN and Intel Ethernet Connection (which is disabled), which I think makes my computer dual honed.
rjj100
Post by rjj100 »
Ran install scripts as per instructions, with IE 11 feature on. Tried IE11 and Vida All-in-One Chrome with same result as before:
Unknown error:
Please contact your local Helpdesk
Could not contact central systems
rjj100
Post by rjj100 »
The Helper Object is installed and enabled on IE11.
I tried Username "1"
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
rjj100 wrote: 20 Jan 2020, 09:00 I did notice I have Hyper-V Virtual Ethernet Adapter, .....
Why are you installing in a Virtual Machine?
VM is a unnecessary complication.
You sure you are patching the VM and not the host?
Active
Past
rjj100
Post by rjj100 »
I thought I was installing in the host. Not aware of any VMs.
If I knew how to disable any VMs, I would happily do so.
rjj100
Post by rjj100 »
I checked and I was running Hyper-V feature. It is off now. I will try running the scripts once again.
rjj100
Post by rjj100 »
Reinstalled. same error. The Hyper-V Ethernet Adapter is no longer there.
rjj100
Post by rjj100 »
Working now I think, but will have to try on a car at a later date. My purpose for installing is to test my DICE unit out. Then I will buy a subscription and the reprogram key fob software so I can make a second key fob.
Here is what I think I did differently:
In addition to the things above re: IE11, no Hyper-V nor its Eth adapter (which may or may not have helped) I did the following:
1) Cleaned my system following a "cleaning guide" which included cccleaner.
2) Ran install scripts again per procedure. Opted for c: directory rather than c:\VIDA, saved with no eUpdate and closed
3) This time had the http://localhost/Vida/PreLogin.do failure.
4) Downloaded RHP's executable patch rather than the 3 install scripts and ran it.
Wish I could be more helpful as to what went wrong. The error may have been in the license file.
Thank you RHP again.
gfego1
Year and Model: 2012 S60
Post by gfego1 »
Where is this repack iso?
RickHaleParker
gfego1 wrote: 27 Mar 2020, 16:23 Where is this repack iso?
Read page #16.
Active
Past
