Water leaking down to front passenger seats from sunproof
biskandar
Year and Model: 2005 XC90
Post by biskandar »
Hi,
I found issue with the sunproof's exhaust water pipe, the end of the pipe was broken .
And many things inside the water pipe, like small tree branches, leaves, and many dirts.
How dirty of the both pipes, as you can see from the color, dark brown !!!
Cheers,
/Benny
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Pass-through valve, Volvo part number 30753148. ~$20.00 each or $30.00 a pair.
Active
Past
biskandar
Post by biskandar »
I found alternative solution to cut the tube in the middle and added the new one, i bought it from home depo .5" with connector.
It works well, and flushed all the dirts inside as well.
shiloh51933
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
I hope it works out for you, I personally dont like adding more couplers or T joints because its another area for potential leaks but I like the ingenuity.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Good find. Like I said in some videos, be aware that this will happen even on cars that never open the sunroof. As they get old, the gasket around the sunroof glass is less flexible and allows water to pass by and into the sunroof tray beneath. The problem is inside the big cities rains comes down with a lot of dust/dirt, which also gets past the seal and within months or years it ends clogging the drain tubes.
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
Nice solution! I ended up reusing the dirty drain tube and replacing the elbows with these. I imagine I'll have to redo these at some point since the smaller inner diameter will create some back pressure.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
