seems to me like the alarm system activated & killed the ignition -- but not beeping the horn. Wife had AAA & they say the battery seems OK.
WtF ???
Lately have been getting intermittant Check Engine and ABS lights. Noticed the ABS light came on after I braked fairly hard.
EDIT: the way to deactivate the alarm (& I guess from the reply below, the "immobilizer' is a separate circuit) is to lock & unlock the DRIVERS side door with the key.
Usually what happens is someone reaches thru an open window & opens the locked door, that will trigger the system.
won't start, turn signal lights flashing
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
No start with flashing indicators is indicative of the immobiliser being triggered. If you have a key fob then unlocking the car via that should fix the immobiliser issues. If you do not, or that does not work, try the following :
http://www.vpcuk.org/forums/archive/ind ... be87dba889
I do not know if this could be linked to your intermittent lights.
850forum
- Year and Model: 1995 850 turbo wagon
- Been thanked: 6 times
My wife says that she did lock & unlock the drivers side door several times but still no start.
But now it IS starting. The shop guy made it start, and when I got up there it also started for me.
Wondering if the alarm is only wired to the low note horn -- which doesn't work anymore?
Going to let the shop look at it, other stuff needs done anyway.
re above link to permanently deactivate immobilizer -- why would one want to do that? How do you re-activate it? I can't believe that just pulling Fuse 16 will permanently deactivate it, it could get pulled for all sorts of reasons when someone is in the fuse box. Oh, maybe only when both #6 and #16 are pulled at the same time? Still, why would one want to do this?
The full version shows a photo of where the under-hood part that you have to pull is located. But there is no arrow showing exactly what part is meant, I see a bunch of stuff.
What is a "phase 2 n plate" car?
NEVER OPEN THE HOOD !!!
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Phase 2 "N" plate car is just a UK thing.
Phase 1 is 850 '91-'95.
Phase 2 is 850 '95-'97.
"N" plate is UK thing for a year of the car.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Cookeh
As above, N in this case means the first letter of the cars registration, which govens the year of registration (1995).
It doesn't permanently deactivate it, don't know why that is in there. Had to do mine that way almost 2 years ago, immobiliser still works just fine. The fuse order is important, and does make a difference.
Immobiliser and alarm system have their own horn, which have batteries that can and do die, as do the horns eventually.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
US models usually just have a single horn
mounted high on the center of the firewall.
Just a plain old round horn - Not electronic,
no battery, just a two wire plug.
What often happens to them is that the center
nut loosens, falls off and the horn’s metal disc
diaphram disappears... Plenty more in the yards!
850forum
They replaced my bad horn this summer, so if there is only one, then I dunno what the no-start fault might have been.
- 1430 Views
Last post by Abrown99
- 440 Views
Last post by blueechosf
- 1076 Views
Last post by kyngofpop
- 12 Replies
- 2903 Views
- 1240 Views
Last post by regent
