I have S70 2.5t 98r B5254t and I have no idea. I replaced:
Spark plug
Ingition cable
Rotor
Cap
Ingition coil
Crankshaft sensor
Camshaft sensor
TPS
O2 sensor
Coolant sensor
Compresion is ok. No air leak i thing. No fault code.
When I drive, car have 1s misfire on 20 kilometers. Sometimes more often, sometimes less often. Sometime when engine working on idle, rotation degrese to 500 a grow up back to 900 in one sec.
I have idea that a ecu is broken.
S70 2.5t misfire
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Parts that had been replaced....are they OE,OEM or aftermarket?
Which spark plugs are used?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Rotor & cap,o2 sensor,crankshaft,camshaft sensors...coil MUST be OEM Bosch.
ECT especially MUST be OE Volvo or at least Vernet.
Since almost all parts are aftermarket it's hard to diagnose the problem.
LPG could also make problems.
Spark plugs should be OE Volvo for turbo engines or cheap copper ones (NGK or Bosch)gapped properly because gap is critical for turbo engines.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- RickHaleParker
- Been thanked: 979 times
Sounds more like something dragging the engine down but it is intermittent, like an Alternator bearing starting to go or a A/C compressor clutch going out and binding. Check everything on the Timing belt and the Auxiliary belt.radek93 wrote: 31 Jan 2020, 15:41 When I drive, car have 1s misfire on 20 kilometers. Sometimes more often, sometimes less often. Sometime when engine working on idle, rotation degrese to 500 a grow up back to 900 in one sec.
Active
Past
Past
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Put the old plugs back in. I know someone recently that got a plug that went bad after a week or two. Drove the guy nuts...
radek93
- Year and Model: S70 98
- Has thanked: 2 times
- Been thanked: 3 times
I have this problem since four years. Oem volvo plugs. Ngk plugs. Brisk plugs. All that same problem.wizechatmgr wrote: 31 Jan 2020, 21:34 Put the old plugs back in. I know someone recently that got a plug that went bad after a week or two. Drove the guy nuts...
- misha
Then...LPG system might be the cause of your problems.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
michael8888
- Year and Model: v70 t5m 1998
- Been thanked: 4 times
I found after going over a year with the same issue and replaced everything that the culprit was the thermostat sensor that's at the thermostat housing. A $13 part plus a new thermostat while I was there. ECU reads the temp wrong from the sensor and adds more fuel to the mix to cool the temp.
Also, check that all electrical connections are good and clean. use some dielectric grease. Be sure the wires from the cam sensor are not near the ignition wires. that may cause some em feedback.
- 19 Replies
- 10256 Views
Last post by Barledge
- 9 Replies
- 3429 Views
Last post by E Showell
- 26 Replies
- 4337 Views
Last post by Sommerfeldt
- 585 Views
- 517 Views
Last post by raykan
