Georgeandkira
Has thanked: 64 times
Been thanked: 69 times
Post by Georgeandkira »
I was floored by my 2007 V70 after tallying a 600+ mile weekend drive and seeing >30.4 mpg.
Yes, it was "all highway" and yes, I filled it with premium.
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Georgeandkira wrote: 21 Jan 2020, 06:49 I was floored by my 2007 V70 after tallying a 600+ mile weekend drive and seeing >30.4 mpg.
Sounds pretty average for a long distance trip to me :D
Rattnalle
Post by Rattnalle »
Replaced the strut bearing on one side. From sounding like it'd fall apart to completely silent in barely two hours work. You can sort of see why it made so much noise. Plus the bearing itself felt like it was full of sand.
I got to use the angle grinder as well :D
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
By shiloh51933:
Just replaced both front Macpherson Strut Assemblies(FCS) along with new Sway Bar Links(Moog) and Tie Rod Ends (Moog). The L/F was squeaking so badly that my hated driver XC90 and was borrowing my 2004 XC70. I kept the Volvo/Sachs set that I removed, the Volvo/Sachs set was actually the first replacement set that Ramsey Volvo had installed for the original owner at 85k mileage. I want the springs just in case this set of FCS strut assemblies fail too quickly. FCS does back them with a Lifetime warranty but I'm not changing them every year if they don't last. So far they ride beautifully, so time will tell.
Also -> Amazon link
Skymongrel
Year and Model: 2023 XC90, S80 2007
Has thanked: 19 times
Been thanked: 19 times
Post by Skymongrel »
Pulled my 2006 XC70 (158k) in the driveway and with the mild temperatures, 38F, installed a new high pressure windshield washer headlamp pump and new pump gaskets to address a bad reservoir leak. Also, put in new fog lamp bulbs since the bumper was off and put in a new fuel filter since I can't remember having ever done that!
I think I read this on the site; that third reservoir bolt is a PIA. Finally loosened the other two and pulled the washer pump out to get clear access to the bolt hole. Left the bolt loose, reinstalled the pump and tightened all bolts. Headlamp washer that has never worked works! Cool!
Has thanked: 1505 times
Been thanked: 3818 times
+10,000 points to Ratnalle for wearing all the safety equipment
On the topic of safety, the weekly winner of how to blow up your P2 with innovative petrol tank wiring
Rattnalle
Post by Rattnalle »
I'm still young and (relatively) undamaged.
shiloh51933
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
2004 Volvo XC70 model w/Factory HID headlight assemblies/self leveling system.
The tensioner pulley for the serpentine belt broke off, just the actual plastic pulley. Everything else on the tensioner was still intact, including the pulley bolt. I could have just replaced the actual pulley but I decided to replace the entire unit. I'm sure after a quarter million miles that I got my money's worth out of the tensioner. The tensioner would probably fail at some point in the future, so just replace it while I'm in there. I purchased the INA Tensioner from FCPEURO.COM. INA is the actual factory manufacturer for Volvo, so the part come inside an OEM box instead of a Blue Box.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- Pete -
Has thanked: 80 times
Been thanked: 175 times
Post by - Pete - »
Definitely dodged a big bullet there Shiloh :o
One thing that’s always bothered me about P2’s is how the arse end of these cars reminds me rather vividly of a “sulky”. As in, the little trailer that is towed behind a walk-behind zero-turn mower - the operator stands on it whilst operating said ZT mower.
I’ve replaced quite a few parts trying to mitigate this annoyance but never successfully pinpointed the source of why the back end of these has always felt like it’s disconnected, along for the ride, just kinda wandering around back there. Hit a bump & you feel the rear end squirm around in an unpredictable manner. I’ve seen the term “side-hop” used in reference to P2 Volvo’s, particularly the S/VR’s.
Well, I think I’ve finally figured it out, at least in part. I’m sure lots of you have looked at the various moving parts in your rear suspension & have noticed there’s so many things connecting this to that, and that to the subframe etc. Amazing how it all works, well sort of works. You’ve also probably noticed torn bushings at the front attachment point for your trailing arms.
For the longest time I just thought the area where the tear is plainly visible on the front & rear of where the bolt passes through was there for a reason; to allow movement as the suspension travels up and down. Well looking at the new bushings there really is no way for them to allow for as much movement as the bushings these cars originally came with.
My theory is that the old bushing allowed for, over many years of use and hundreds of thousands of push/pulls, too much movement, and as a result the loosey goosey rear end feel. Let’s replace them then, looks very accessible & cant be that hard. So I researched unendingly & came up with a couple XC90 tutorials (which evidently have steel rear subframes & lots more working room), 1 decent V70R tutorial, and some horror stories about dealerships not being willing to do the job due to a significant risk of cracking the rear subframe. I have no idea how much credence there is to the supposed risk, but after having done bushings on (edit) 4 cars in the last week, I can attest that there does seem to be some validity to these stories.
Replacement of them is pretty straight forward. Keeping in mind the stories I’d read about dealerships not taking the job & there being a risk of cracking the rear subframe, I was very cautious on the first car I did, our V70R. This car had the most noticeable “side-hop” of all our P2’s, probably due in part to the 245 series tires, which I’ve switched out to OEM sized 235’s.
Where I feel the risk to cracking the subframe lies is as follows. To get access to the bushings you will need to remove the trailing arm. Very simple to remove, but you can’t remove the bolts unless the suspension is compressed. So get your jack under the knuckle/control arm (directly below the lower strut mount) & mash it back up, just to the point before it begins to lift the car off the stands. Now the bolts can come out & trailing arm can be removed.
I read that removing the bracket (pic below) that attaches the front of the subframe to the car is necessary so you can get your mini press tool situated to press the old bushing out/new one in. Removing this bracket is not necessary, for the record. I would leave it right where it is!
So with my jack keeping the suspension compressed, I took that bracket off. Then, I ever so slowly began to back the pressure off my jack, and stopped almost immediately. I noticed that front corner of the subframe began to lower from the car. The suspension actually twists the entire aluminium subframe as it decompresses. I stopped instantly & realized this has got to be why cracked rear subframes exist due to replacing these bushings. So mashed the suspension back up & put the bracket back on.
You do need to take this bracket & move it out of the way. There is a plastic push clip that secures the hard brake line to the backside of the bracket I mentioned just above this paragraph. Sorry the photo is upside down. I tried re-orienting it & it still shows up upside down.
The rest of the replacement is good exercise, about an hour per side I would say. I did run into issues with our 281k XC70 & also the V70 AWD & ended up having to cut slots in the original bushings with a recip saw. They were just so seized in their cozy confines. Once that was done I could practically tap them out with a drift. I would recommend taking your sawzall & cutting a slot in your original bushings. Try just the bottom or top at first, if it’s still stuck cut a slot in the opposite side as well. I think it’s a combination of the rapid vibration as well as the relief created by the removal of material. Obviously don’t cut into the subframe!
Here’s the press tool I rigged up. A few 2” PVC repair couplings, one of which you cut in half (have a couple spares in case one cracks), a modified 2” galvanized plug, 7/16” grade 8 bolt, washers that fit on it, nut, and a couple steel plates cut & drilled to fit. I used a coarse thread bolt & even after doing (edit) 8 bushings with the same bolt and nut the threads hadn’t deformed at all. If anyone wants to borrow it just gimme a holler.
Here’s the 2nd example of a cracked PVC “receiver”, wear safety glasses. I may make a steel or aluminum receiver since I ended up cracking 2 of my PVC ones. Even being cracked they still allowed me to finish drawing the bushings in.
WEAR SAFETY GLASSES!
On the car:
Pressing old out
Pressing old out
I can make a dedicated thread of this if anyone thinks it’d be worthwhile to have on hand here. I took lots of photos & would be glad to share them. Tool is easy to make & free to borrow if you don’t want to make one. Just pay shipping & return it afterwords. The PVC repair couplers are really tough but do deform some with all the pressure. I only had one of my couplers (which I had shortened by cutting in half) crack on me. Even with it cracked I still was able to draw the bushing all the way in to the subframe.
By the way, the Meyle bushings on FCP are Chinese. The Volvo brand bushings are Slovakian made, as are the Lemforders according to the rep I spoke to. Funny thing, the Volvo brand bushings actually have the Lemforder logo & “Ford” embossed on the rubber.
I used 6 Volvo/Lemforder bushings and 2 of the Chinese Meyles just for comparison purposes.
Rattnalle
Post by Rattnalle »
Interesting! I would definitely day it deserves a thread of its own.
The feeling became less pronounced on my car when I fitted reinforced springs. Probably because everything moves less. But seams in concrete highways, bridges and most of all the tram tracks* we have around here can still sometimes give that jumpy feeling.
*Tram tracks in a city built mostly on clay move a bit. The pavement doesn't. So there's a gap each side each track after a couple of years. And sometimes a difference in height. Uncomfortable in a car. Potentially deadly on a bicycle.
