Replacing up& down02 sensors, coil packs
beldon42
Year and Model: 2001 v70
Post by beldon42 »
Currently my volvo v70 will not pass NY State Inspection. Hesitates on start-up. A general mechanic told me to replace both upstream and downstream 02 sensors and coil packs. Any suggestions or advice on this? I am new to volvo.
Thanks,
Dave
Been thanked: 4065 times
I’ve actually driven through Taberg, albeit I was lost, testing the theory that do all roads indeed lead to a Rome.
Greetings.
You are probably failing inspection due the presence of engine codes, stored in your engine computer, or ECM.
You need to read those codes and get the. Actual numbers like Pxxxx.
Most trouble codes are caused by vacuum leaks and broken hoses, occasionally plugs and coils go bad in these cars too. Hold off on oxygen sensors for now
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
How many miles ? Turbo? You only need to replace the upstream O2 for the emissions, but some mechanics are too quick to give simple answers. Can be other things other than a front O2 sensor. Give us more details if you have, and try to find the culprit with certitude. As for the coils, unless you have a lot of miles, just need to replace 1 or 2 when they fail - they will give a shake or missing. Use Bosch from Fcpeuro. More important is to have the correct spark plugs of the right brand.
