We recovered a v70 with a head gasket problem to my driveway and it will live again.
Symptoms, loss of coolant from hose chafe, upper radiator hose
Little compression in 1,2,4,5
150 psi in 3
Timing belt intact
Temps soared to 38F so I did all the upper cylinder head disconnects, deep great, and popped off the four exhaust manifold bolts...zip zip zip zip by Bosch.
Air cleaner and fuel injection rail off
Rear engine mount off
One thermostat bolt head stripped out. Since head is coming off, that will be easy to remove on bench.
My garage clears on Feb 17, hope to finish shortly thereafter.
1998 V70NAM56 (NOW ENGINE SWAP) , winter 2020 "The Orange Mountain"
- Been thanked: 4064 times
- RickHaleParker
- Been thanked: 977 times
1998 V70 in Orange .... Saffron Pearl Metallic, paint code 435?
Active
Past
Past
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Pictures, or it didn't happen . . .
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
I hope you play some Mandolin Orange while your doing this job
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
Well, 31F and cold rain, with car stuck outside until FEB17
I think I am going to call HR and take mechanic vacation day this weekend.
Car is in the beautiful Silver Sand Metallic and Charcoal interior.
Technically it should be the Green Mountain Project, but the family knows why its Orange...
- E Showell
Go 'Cuse!
'95 855 auto (sold)
'95 855 auto (sold)
- 850 LPT
Shouldn't it be the white mountain project? I think Mark needs to chime in here.
13' Honda Odyssey
13' Honda Odyssey
- Has thanked: 316 times
- Been thanked: 531 times
Time for a harbor freight canopy and a heater!
I'm just glad the rain finally stopped down here. It's been miserable.
Well, I am a glutton for punishment - instead of lunch I:
Got the heat shield, water pipe, and TB off, and slackened the top cover bolts in prep for removal.
Cold, wet, and wind got me after an hour though. Buttoned up
Dropped one 3 inch extension bar somewhere into engine.
My sharpie froze, so I add to notes here.
2 M8 sheild Nuts
2 M6 water pipe bolt
1 M6 ground strap bolt
2 M8 sheild Nuts
- 850 LPT
Man, these boys from the frozen North are a tough breed.
13' Honda Odyssey
13' Honda Odyssey
- 9 Replies
- 2443 Views
Last post by wizechatmgr
- 1950 Views
Last post by foggydogg
- 35 Replies
- 16960 Views
- 14 Replies
- 5849 Views
Last post by V70r carbon
- 9 Replies
- 3225 Views
Last post by BlackBart
