Parking brake cables Topic is solved
Has thanked: 2203 times
Been thanked: 1852 times
That limited use is also part of the problem as not using it allows it to seize through lack of use. Not necessarily just the cable but the mechanism, which in turn strains the cable and breaks the seal and sheath just forward of the rear wheels allowing moisture in.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Driver's side works perfectly,cable sheath have no cracks.
The main problem with passenger's side is that cable sheath is cracked in two usual spots and it seems that this is where the cable seized.
Expander have zero rust on it.
Driver's side is perfect.
I will report results.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
Parking brake functionality restored!
Cable was seized.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
A real pain to replace, but good to hear full function restored!
misha
Post by misha »
It wasn't so bad like i was expected it to be.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
