2007 XC70 start problem
Mpdog37
Year and Model: 2007 XC70
Post by Mpdog37 »
Strange starting issue with my 2007 XC70, turn key to start, cranks 3 times then stops, no start, turn key off try to start again, cranks 3 times then stops... any ideas why this could happen.
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
Not enough info. Show please errors from VIDA.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Same when jump starting ?
May also see the wires at the starter, also this one at the rad fan viewtopic.php?f=9&t=92688
Mpdog37
Post by Mpdog37 »
No diagnostic at this point, apartment mechanic, so can’t really disassemble much, got some stink eyes, checked grounds, and starter wiring, battery went dead, tried jumpbox, same thing, tried new battery, same thing, crank pulley marked and turning, compression seems good, doesn’t seem immobilized, I don’t know, will seek diagnostic and see what comes up... I’ve had (5) 122’s, and 3 v70’ wagons, this is first 21st century, and its over my head, give me a 4 banger and I’m all good, Lol....
Mpdog37
Post by Mpdog37 »
Ok, took to Volvo mechanic, trust him good guy, however code cannot be read, interior pops up, windows, lights etc, but engine side of CEM not readable, ugh! Recommends replacing CEM so code can be read, but at 1500 not gonna happen. I am going to pull CEM and use contact cleaner with brush and clean the hell out of connections, see what happens. Also, starter pulling too many amps, needs replaced, and ordered one. Question? Could starter pulling too many amps actually prevent the spark/ start?
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
I would skip what good guy is suggesting for now, it smells like burnt starter.
Interference from dying starter hides crankshaft position sensor, which ECM uses for timing.
Mpdog37
Post by Mpdog37 »
10/4...will let you know, thanks
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Mpdog37 wrote: 24 Feb 2020, 17:18 Ok, took to Volvo mechanic, trust him good guy, however code cannot be read, interior pops up, windows, lights etc, but engine side of CEM not readable, ugh! Recommends replacing CEM so code can be read, but at 1500 not gonna happen.
Uh-uh ... sound like a CANbus issue not a CEM issue. I'm not so sure about that guy.
Mpdog37 wrote: 24 Feb 2020, 17:18 I am going to pull CEM and use contact cleaner with brush and clean the hell out of connections, see what happens.
That is the correct path. Checking the CANbus from the CEM to ECM for shorts and opens is in order.
Active
Past
Mpdog37
Post by Mpdog37 »
Well the plot thickens, contacted previous owner and CEM was replaced and programmed with new key and ignition and ring. I have new starter, pulled CEM, cleaned and will install tomorrow along with new battery. I used turn signal button search before pulling CEM and said ABS and immobilized, so will continue from there
Mpdog37
Post by Mpdog37 »
Does remote lock/unlock 5x reset immobilization on 2007 xc70?
