I've gotten more used to the cold this season... my inner Jersey is coming back! I just want the sun... it's been nothing but clouds this winter. The cold wet weather makes it hard to work on cars, but some of us try to get through!
Meanwhile, it was 70 degrees Wednesday, we had a tornado that ended 1/2 a mile up the street from me (literally the next street over in my neighborhood) on Thursday, and now today it's supposed to snow this afternoon. 4 seasons in just a few days... welcome to NC!
1998 V70NAM56 (NOW ENGINE SWAP) , winter 2020 "The Orange Mountain"
- Has thanked: 316 times
- Been thanked: 531 times
- Been thanked: 4067 times
That Miata would have blown away. Good thing those heavy Volvos stayed gRounded
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
I'm a spoiled whimp in comparison and really don't care about the weather. Decide which car I want to work on and move it in the garage Friday evening. Then turn the heat on before breakfast Saturday morning. It's toasty by the time I turned the laptop on to play some of my favorite music while I wrench
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
My crew comes next Monday, my 7th anniversary on MVS, to unload the 1998 parts car and open up my garage for the rest of this job.
Cold, wet, snotty ice rain today - lousy outside wrenching weather. I can do cold, but not cold and wet.
Warmer today, probably 63 right now and cloudy... awaiting MORE rain later tonight into tomorrow and Wednesday. We got one sunny day yesterday, at least.
Now I need to load up the heavy Volvo and recycle some old oil and coolant and return a battery core to the junkyard. At least I got the wheels swapped on the 940s today, the '93 is ready to go for the most part.
You should change this thread to the MVS wrenching weather thread!
I was hoping for a wam week in FEB to get Marks Silver Bullet back on the road, but so far, the weather has not been kind.
Well, four hours in and I just got to cam cover removal. I got badly jammed on the two intake manifold 12 mm bolts underneath - both were stripped heads, so I ended up removing at the block bracket. Also stripped, but Managed to work it out with better access than the top two.
So cam cover removal next - whats the favorite poison for that?
Cam cover pliers??
Jam a chisel into the groove and air hammer away??
Cam cover pliers??
markone
- Year and Model: 2007 V70
- Has thanked: 21 times
- Been thanked: 14 times
Steve is off to the races with the Orange idea, as Syracuse was indeed the intended destination when trouble ensued. Car IS registered in the Green Mountain State. I can see the White Mountains of New Hampshire from my house. So you all are iin good shape on the Color Wheel code names.850 LPT wrote: 07 Feb 2020, 07:47 Shouldn't it be the white mountain project? I think Mark needs to chime in here.
Daughter Dearest actually attends SUNY ESF in Syracuse.According to their published ESF Branding and Style Guide, "Primary colors are the green, white, yellow, brown and black in our logo."
So I have to wonder about Orange Mountain, although there is little doubt about Steve waging an uphill battle. Cold, wet and alone.
Gratitude is all I got.
2006 V70 NA/manual trans, 165k
2007 V70, NA/manual trans, 143k miles
2023 BMW X1, 29k miles
2018 Jeep Grand Cherokee LTD, 91k miles
2007 Malibu Response LXi, Ebony/white, 340 hp, 395 hours
1997 850 Sedan NA, manual trans, sold at 330k miles
1998 V70, NA/manual trans, sold at 365k miles
Hoping someone will save me having to buy the $100 cam cover pliers - but there is always the MVS tool program, worst case.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
It's been a while (thankfully) since I've had to do this, but here's what I remember:
If the cam cover is the same as on the 850's, I've used a 3/8" or 1/2" square drive to pop the seal.
On the 850 if the crank timing mark is zeroed, #5 valves (I think on the intake side) will be loaded open under the cam cover.
To ensure a level lift of the cover to avoid damaging the seal wells, I leave a couple of bolts at #5 in but loosened maybe an eighth to a quarter inch, both intake and exhaust side. Then with all the other cover bolts removed use the square drive of your ratchet under the edge of the cover to pop it. There will be no lifting force from open valves under the #'s 1-4, only under #5.
Then working back and forth across the I&E's at #5 end, remove those bolts and keeping it level until the ends are clear, lift it off.
- 9 Replies
- 2460 Views
Last post by wizechatmgr
- 1972 Views
Last post by foggydogg
- 35 Replies
- 17105 Views
- 14 Replies
- 5878 Views
Last post by V70r carbon
- 9 Replies
- 3247 Views
Last post by BlackBart
