Newbie here
MavrickNOTB
Year and Model: 2004 S60 2.5T FWD
Post by MavrickNOTB »
Hope everyone is having a great Monday. New member as of this morning! I’ve recently obtained my wife’s ‘04 S60 2.5t FWD after buying her an ‘18 V60 a few months ago. I’ve now been given the green light to do whatever I please with it! Nothing major for now but I’ve came across a salvaged ‘09 S60. I know it is still based on the P2 platform but was curious how interchangeable the parts can be. Mainly needing the rear bumper and could always have the seats as back up if it’d work. Forgive me for the possible “dumb” questions but I’ve realized previous expertise and enthusiasts are better than google.
Thanks in advance!
Has thanked: 1611 times
Been thanked: 4072 times
Welcome !!
I don't know the S90 platform at all, but the Volvo Web Store is a great reference for OEM part numbers.
Its a bit tedious, but you can enter each model year number into the finder, then pull up parts and check the fitment guide to see if they apply.
Accuracy, about 99.5%, vs the 43% accuracy of Rock Auto or typically parts stores.
Mitsubishi turbo 15T - "Fits all Volvos" - my favourite
chris11211
Year and Model: 2006 s60 2.5T
Has thanked: 7 times
Been thanked: 29 times
Post by chris11211 »
The refresh is in 05, so the difference should be afaik
-headlights
-throttle body (check if it's bosch/ non bosch is terrible)
-radio/ac assembly
-steering fluid reservoir
-control arms and ball joint
-abs computer
-fuel pump
-front bumper
-side mirror housing
Supergrunged
Year and Model: 2005 S60R
Has thanked: 3 times
Been thanked: 4 times
Post by Supergrunged »
Most body parts are interchangeable. The electronics however are not between that 09, and 04. The seats, you'll have to swap the skins. The heater connections are the same, but the airbag is different, so it will throw an SRS code just direct swapping the seats.
But rear bumper, will swap, easy enough, and you can put a body kit on the newer bumper for $100 ;) The older ones were one piece. Side skirts will fit all years as well.
markgeorge5831
Year and Model: S40
Post by markgeorge5831 »
Hello & Welcome.
