You have to read the chart I linked to very carefully. Too carefully , actually
The columns are shifted so that the wrong numbers are aligned with the temperatures.
Awful.
I have to put a note on this in there
4K ohm at 10 C is close to spec
95 850 Rough idle, needs gas
- Has thanked: 1613 times
- Been thanked: 4078 times
Well , it has to work over the whole range, not just at a single point. The engine almost doubles the fuel injected at cold start, so if the resistance isnt right, it won't run.
Hmm ok.. Would the best way of checking it be through taking it out and boiling it in water to see the temp and resistance? Or would it be enough to drive the car around for some time and checking the resistance then?
- RickHaleParker
- Been thanked: 980 times
Measured when it is not connected to the sensor or when it is plugged into the sensor?
Active
Past
Past
- Has thanked: 312 times
- Been thanked: 818 times
Absolutely. Boil water, put the sensor in and check it, then turn off the heat and check the resistance at several points as it cools.ebbie wrote: 14 Feb 2020, 07:45 Hmm ok.. Would the best way of checking it be through taking it out and boiling it in water to see the temp and resistance? ...
- RickHaleParker
H2O melts at 0 °C (32 °F) therefore the drip off an Ice cube is 0 °C (32 °F).erikv11 wrote: 14 Feb 2020, 07:58 Absolutely. Boil water, put the sensor in and check it, then turn off the heat and check the resistance at several points as it cools.
Active
Past
Past
Hi Rick, I find your statement of fact irrelevant. There is no doubt some clever intent behind your crypticness, please elaborate!RickHaleParker wrote: 14 Feb 2020, 08:09H2O melts at 0 °C (32 °F) therefore the drip off an Ice cube is 0 °C (32 °F).erikv11 wrote: 14 Feb 2020, 07:58 Absolutely. Boil water, put the sensor in and check it, then turn off the heat and check the resistance at several points as it cools.
Actually, I solved the problem! My mom started googling about my issue and came upon a post about the idle air control valve, where it had gotten stuck. I never really stopped thinking about the IAC, and so I checked on YouTube some people saying the IAC should make a little rattling sound if you shake it. I didn't remember it making any sound when I cleaned it a few days ago, so I went back to the IAC and decided to give it a couple of gentle hits to the valve, and tried to open it manually. Sure enough it opened up now! So I cleaned it again even more and then put some oil too to make it smooth, and ran the valve back and forth a couple of times. Car started perfectly!
I feel stupid for not having checked if the valve opened or not when I cleaned it th first time, I guess I was too nervous about poking around too much.
- 1894 Views
Last post by highmiles
- 242 Views
Last post by jmartin919
- 2786 Views
Last post by DeadEric
- 17 Replies
- 1634 Views
Last post by vtl
- 549 Views
