Cylinder Head Gasket recommendations 3531017
Elwis set with lots of other stuff $114
Corteco
Rein
Genuiine Volvo - FCP doesn't have a listing here??
1998 V70NAM56 (NOW ENGINE SWAP) , winter 2020 "The Orange Mountain"
Awww, Gee...850 LPT wrote: 13 Feb 2020, 16:37 Steve, when an engine overheats like this one, does one ever have to be concerned about the bottom end?
Btw, I am seriously impressed by your work.
I think we have had three bottom ends go bad on the history of this forum, They are really tough. The head goes way before anything in the block gets to damage temperatures.
markone
- Year and Model: 2007 V70
- Has thanked: 21 times
- Been thanked: 14 times
I dunno about hazard pay. You could be soldiering onward here- minus 5 degrees this morning. Balmy eight degrees as the sun begins to fade.
2006 V70 NA/manual trans, 165k
2007 V70, NA/manual trans, 143k miles
2023 BMW X1, 29k miles
2018 Jeep Grand Cherokee LTD, 91k miles
2007 Malibu Response LXi, Ebony/white, 340 hp, 395 hours
1997 850 Sedan NA, manual trans, sold at 330k miles
1998 V70, NA/manual trans, sold at 365k miles
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
I firmly believe that head gasket jobs should only be done in sub 15 degree weather
07 V50 T5 AWD M66 ~146k miles
- RickHaleParker
- Been thanked: 978 times
Something for your wish list, $15.00 - $20.00 .abscate wrote: 14 Feb 2020, 05:45 Omen minute low flame. $160 less a few bad boys saved. I think most will come out easily. Kudos to Volvo for high quality steel studs
Active
Past
Past
With propane and wrench I’ve got 7 studs put in 20 minutes. The last three will get double nutted, MAPP or oxy acetylene and another 30 minutes to get out.
So 10 studs will take one hour at $150’ an hour labor, or $15 per stud
I knew $16 a stud was a ripoff......
It’s like these shops have done this before ...
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
How did I miss this? All this happened in a week?! Impressive. White shirt reminds me of classic Indy mechanics - that's the look!
I finally bought a $49 HF(fright) impact gun to get a 24mm suspension nut off of a Land Rover. Felt a little guilty it was so easy. But the book says 184 ft-lbs, and it was not coming off with pipes and breaker bars, heat, PB, anything.
Harbor Fright
That’s a BlackBart Classic (tm)
Thank goodness I’m in the Deep South. Maple syrup isn’t going to flow at those temps.I dunno about hazard pay. You could be soldiering onward here- minus 5 degrees this morning. Balmy eight degrees as the sun begins to fade.
markone
I'm going to have to move the syrup from the breakfast table into the refrigerator to warm up. Minus 20 this morning.abscate wrote: 14 Feb 2020, 20:25 Thank goodness I’m in the Deep South. Maple syrup isn’t going to flow at those temps.
Yikes. That’s -29C for our EU friends. That’s respectable cold even for SE FIN NOR!
Double nutted the last three exhaust studs and 60 more seconds of propane, all came out easily. Much better torque than vice grip.
Good quality steel studs are the savior here. Thanks Volvo.
Head is ready for shop
- 9 Replies
- 2450 Views
Last post by wizechatmgr
- 1962 Views
Last post by foggydogg
- 35 Replies
- 17033 Views
- 14 Replies
- 5866 Views
Last post by V70r carbon
- 9 Replies
- 3242 Views
Last post by BlackBart
