2006 XC90 2.5T AWD
VIN YV4CZ592461261457
I need to replace the temperature control unit - however when I pulled mine, the only sticker on the back of the unit was labeld 1331308C. From searches I did, this came up with nothing.
It seems the genreic part number for my car is 8697138? But when I checked with a friend, he said he didn't think that part number supported heated seats which I do have.
Any help appreciated - thank you.
Need help finding a part # for my car
wanderdüne
- Year and Model: 2004, 2006 XC90 2.5T
- Has thanked: 6 times
- Been thanked: 45 times
Do you mean the Climate Control Module? Why does it need replaced?
This isn't plug and play and is quite expensive.
bfry
- Year and Model: 2006 XC90 2.5T AWD
- Has thanked: 31 times
Yes - I mean the climate control unit. The knob that controls fan speed isn't working. When i turn it, sometimes it works, sometimes it doesn't, sometimes it turns the other way, sometimes I will spin and spin it and it only moves one click, etc. Blower at first worked on and off with this happening, now it won't work at all.wanderdüne wrote: ↑17 Feb 2020, 20:32 Do you mean the Climate Control Module? Why does it need replaced?
So, when googling the problem, I came across several YouTube videos where people had the same exact thing happen to them and they just pulled the unit and replaced it with a new one and the problem was solved. Used ones seem to be ~$90 bucks - the sellers are up front saying that I need to make sure I get the same part# or it will not work.
Thank you.
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
I think this is what you are looking for?bfry wrote: ↑18 Feb 2020, 08:30Yes - I mean the climate control unit. The knob that controls fan speed isn't working.wanderdüne wrote: ↑17 Feb 2020, 20:32 Do you mean the Climate Control Module? Why does it need replaced?
Thank you.
https://www.volvopartswebstore.com/show ... evel=24666
bfry
MoVolvos wrote: ↑18 Feb 2020, 08:40I think this is what you are looking for?bfry wrote: ↑18 Feb 2020, 08:30Yes - I mean the climate control unit. The knob that controls fan speed isn't working.wanderdüne wrote: ↑17 Feb 2020, 20:32 Do you mean the Climate Control Module? Why does it need replaced?
Thank you.
Thank you for that - but mine looks different, has different knobs, etc.
- MoVolvos
Check the site as they have different models for the year. Maybe one of the other models or a 2007 - 2005 will have the same panel. Good providence.bfry wrote: ↑18 Feb 2020, 08:57Thank you for that - but mine looks different, has different knobs, etc.MoVolvos wrote: ↑18 Feb 2020, 08:40I think this is what you are looking for?
- Has thanked: 1497 times
- Been thanked: 3810 times
With a used part you will have to program software to match your accessory list; it is doubtful that the donor car matches your exactly. Cars aren’t swap and play anymore. You tube videos aren’t useful in this regard.
Semicolon count: one.
wanderdüne
Yes, as far as I know, the dealer won't or can't re-program the used CCM to your car. Again, these are not plug and play; they are discreetly programmed. Probably the best bet would be to go through XemodeX and get the used unit cloned from your existing unit or have yours repaired there. https://xemodex.com/us/climate-control- ... -services/
I think they have decent turnaround time.
- 672 Views
Last post by JRL
- 641 Views
Last post by VolvoTron04
