2007 S80 3.2 w/110k - High Temp Warning, Screeching and (owner) Screaming
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 120 times
Been thanked: 189 times
Post by pgill »
Mike,
You are working your way down the list
High Mileage Maintenance items for 3.2
1. Serpentine belt, tensioner, idler -
The list continues
https://www.freel2.com/forum/topic32504.html
I have done most of the items on the list for both of my 3.2's and both vehicles are very reliable.
Good Luck
Paul
IronMike
Year and Model: 2007 S80 3.2
Has thanked: 5 times
Been thanked: 6 times
Post by IronMike »
No problem, apology not necessary! You. Da. Mon.
Advice appreciated and headed. So, that pulley that "powers" the belt system - I can't budge it in either direction. So the whole serpentine belt, when installed ;), should be able to rotate freely in one direction and not the other? That's interesting, I can't imagine that happening given the frozen feeling of that pulley under the A/C compressor that runs through to the alternator. Does this mean a frozen clutch pulley?
IronMike
Post by IronMike »
Totally, glad to do prev maint when I can. Wish I did this job during the summer but since the A/C and belt was brand new figured the dealer also changed out the pulleys. I have another 2012 with the turbo 3.0 - assume same deal?
pgill wrote: 20 Feb 2020, 09:30 Mike,
The list continues
Good Luck
Paul
pgill
Post by pgill »
IronMike wrote: 20 Feb 2020, 12:16 No problem, apology not necessary! You. Da. Mon.
Yes, my clutch pulley failed by freezing in a locked position
You are 100% correct in what you wrote above.
Thanks
Paul
pgill
Post by pgill »
IronMike wrote: 20 Feb 2020, 12:18 Totally, glad to do prev maint when I can. Wish I did this job during the summer but since the A/C and belt was brand new figured the dealer also changed out the pulleys. I have another 2012 with the turbo 3.0 - assume same deal?
The list continues
Good Luck
Paul
The turbo 3.0T will need the same maintenance
Thanks
Paul
IronMike
Post by IronMike »
Ok, correction. I CAN spin that pulley below the A/C compressor (CCW as viewed from driver's fender) when using the belt thrown around it. Can't spin it CW. I think my confusion was that this isn't really called an alternator pulley, it's the crankshaft pulley? https://parts.volvocars.ca/p/Volvo_2007 ... 16803.html
pgill
Post by pgill »
Mike,
The crankshaft drives a gear in the READ and the pulley is connected to that gear
Good Luck
Paul
pgill
Post by pgill »
IronMike wrote: 21 Feb 2020, 11:45 Ok, correction. I CAN spin that pulley below the A/C compressor (CCW as viewed from driver's fender) when using the belt thrown around it. Can't spin it CW. I think my confusion was that this isn't really called an alternator pulley, it's the crankshaft pulley? https://parts.volvocars.ca/p/Volvo_2007 ... 16803.html
The naming for the clutched pulley is confusing.
Based on your comments I wouldn't replace the clutched pulley, it seem to still be functional.
I just check mine by moving the belt once every six months when I change the oil (It moves just as you described)
Good Luck
Paul
IronMike
Post by IronMike »
Just zoomed in on my own pic, guess I didn’t notice this before thought it was a seam...pretty sure it’s a crack...
IronMike
Post by IronMike »
Thanks for that video Paul!
