MAP Sensor location Topic is solved
MALL240
Year and Model: 1991 240 2.3 turbo
Has thanked: 28 times
Post by MALL240 »
Hi, have a 240 2.3 1990. I spend 3 days searching the MAP sensor, but i didnt find it... I read manuals, diagrams... nothing... can somebody help? Thanks a lot
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Why would you be looking for a MAP (Manifold Absolute Pressure) sensor on a 1990 240?
Active
Past
MALL240
Post by MALL240 »
jajajajajaja please tell me this model use this!!! Really?? Dont use MAP this model? Why in the parts online shop say me this MAP its working?
Thanks
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
MALL240 wrote: 24 Feb 2020, 01:25...240 2.3 1990...Why in the parts online shop say me this MAP its working?
In US, Volvo used
1982 B21F Bosch LH 1.0 / 2.0
1983-1984 Bosch LH 2.1
1985-1989 Bosch LH 2.2
1989-1993 Bosch LH 2.4
1990-1993 Bosch LH 3.1
LH 2.3 - "... Porsche 928 from the 1987 model year until the car ceased production in 1994. Earlier cars, LH equipped, such as the Euro S2 (84 -’86) and the US market early 32v (’85 – ’86) used the LH 2.2 system."
Please cite this online site where your 240 Volvo has a LH 2.3.
Bosch's LHs used an AMM (MAF)....MAF and MAP are not the same. Is yours a LH 2.4 or LH 3.1?
MALL240
Post by MALL240 »
HI, LH 2.4 115cv CAT. My car have MAF. I didnt know i dont have MAP... b ut... i cant understand that this part shows like its fit on my car... should be wrong...
My car is from Switzerland.
Este producto corresponde a su VOLVO 240 Familiar (P245) 2.3 i CAT
NGK Sensor, presión colector de admisión 92477 originales de calidad
MOTOR
SENSOR DE PRESIÓN DEL AIRE DE ADMISIÓN
NGK SENSOR, PRESIÓN COLECTOR DE ADMISIÓN
https://www.autodoc.es/ngk/10506047
thanks.
On the up side you can read: This product is for your VOLVO 240 wagon (P245) 2.3 i CAT.
MALL240
Post by MALL240 »
PASSENGER CAR COMPATIBILITY
VOLVO 240 Family (P245) 2.3 i CAT, Year 08.1986 - 07.1993, 2316 , 115 HP
VOLVO
VOLVO 240 Saloon (P242, P244) (Year 08.1986 - 07.1993, 113 - 115 HP, Gasoline)
VOLVO 240 Family (P245) (Year 08.1986 - 07.1993, 113 - 115 HP, Gasoline)
RickHaleParker
NGK 92477 = Volvo 1378162
On a metal plate near the left fender. Rubber hose running to intake manifold.
Active
Past
MALL240
Post by MALL240 »
Hi RIck, thanks a lot. I spend almost days looking in that place, but i didt see nothing... its possible the MAP was inside of the wheel way? unnnder the metal? Becouse i count all the rubber house. In the intake manifold only goes two tubes, and goes to the air filter on the front left wheel...
I believe for the acces to the MAP its under the road pass, and i need disassemble wheel arch?
Thanks a lot!
Can i send a photos? thanks
My engine is B230F
RickHaleParker
Looks like it is at same location as the Ignition coil.
Active
Past
MALL240
Post by MALL240 »
Thanks Rick, cant see nothing...i dond understand
in the 1 image, can i see 2 holes...pfff maybe under??
Captura de pantalla 2020-02-25 a las 9.15.06.png (1.76 MiB) Viewed 3660 times
