Starting from yesterday driving home from work, I heard a rattling/metal noise from the front. Whenever I accelerated the car, noise happened. When my foot off gas pedal, noise disappear immediately. It wasn't that loud yesterday afternoon. Today, it became more louder whenever I stepped on gas pedal. I lowered driver side window when rattling/metal noise happened, Even my wife could hear it when all windows were up. I could hear the noise when driving no matter windows up/down. It became very loud when I accelerated up hill. So noise level was proportional to the acceleration.
What could be this rattling/metal noise ? Car drives fine, no fault codes. I don't feel any shaking or vibration when driving or when braking. Just this annoying rattling/metal noise.
Thanks,
Ching-Ho Cheng
Rattling/Metal Noise when stepping on gas pedal
- Been thanked: 4064 times
Two most like candidates
Loose metal plates under car touching exhaust , or perhaps axle shafts
Brake backing plates slightly bent out of position and touchingwheels
- Has thanked: 2197 times
- Been thanked: 1850 times
Abscate has listed the probable candidates. Heat shields are prone to falling of as the mounting holes react with the steel mounting bolts and washers which eats a hole through them.
Other thing to add to the list the exhaust heat shield broken mounts.
lcc014
- Year and Model: 855, 1995
- Has thanked: 2 times
- Been thanked: 11 times
Thank you for the suggestion. Brake backing plates are all gone on both side of the front brake for a long while. So, I will put the car on ramp to check for any loose heat shield.
Ching-Ho Cheng
Ching-Ho Cheng
lcc014
I drove the car onto ramp and checked around under the front of the car. Nothing loose. The heat shield above converter was tight. Then I started the car while car was on ramp and heard the noise of exhaust was not quite "right/normal". Sound like a leak but not very loud. Then I drove the car last night with front windows down (driver and passenger). I could hear the loud sound from the front during acceleration - exhaust, not rattling/metal. So most likely it was the exhaust leak, exhaust manifold ? The exhaust from converter to the tail pipe was "new", not too long ago, about 1 year old.
- Has thanked: 316 times
- Been thanked: 531 times
Is your car turbo? If not, remove the exhaust manifold heat shield and check the flexible portion of the exhaust manifold. I've seen them rot out and leak, causing a LOT of noise.
lcc014
Mine car is NA. I did look at that flex portion of the exhaust manifold from underneath, seems fine. I did not remove the heat shield from above to check. One thing though the wire mesh wrapped around that flex elbow had been long gone for a long while.
Have you tried tapping the muffler system with a small hammer to see if you can make the rattle appear?
Neil
Neil
lcc014
Muffler is "new", replaced last May. @bmdubya1198 hit the bull eye. It was the flex elbow of the exhaust manifold. I will have Volvo garage to replace the manifold.
Thanks,
Ching-Ho Cheng
Thanks,
Ching-Ho Cheng
Glad you found it! My cousin's old NA wagon had a nasty leak from that section of the manifold, it made the car sound very rattly and raspy.
