1998 V70NAM56 (NOW ENGINE SWAP) , winter 2020 "The Orange Mountain"
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
abscate wrote: 21 Feb 2020, 20:40 I’ve got deep brinnelling andvalve issues too, so I think one has shuffled off its single mortal coil.
I'm dying to put that head on top of the grill though =P
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Ain't no bbq gonna fix that
BMW 540i 2002
S70 Base 2000
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
wizechatmgr wrote: 22 Feb 2020, 08:39 I'm dying to put that head on top of the grill though =P
Yeah, I kinda want to see the head on the grill now.
Has thanked: 311 times
Been thanked: 817 times
agreed. something like this:
<<<brats>>>
|===head===|
wizechatmgr
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
wizechatmgr wrote: 23 Feb 2020, 03:02 Apparently it isn't fully taboo...
Baked not grilled.
Active
Past
kallekula
Post by kallekula »
RickHaleParker wrote: 23 Feb 2020, 12:08
Baked not grilled.
There you go, had several heads done this way, but not with a fancy oven like that. Regular backyard bbq big enough works just fine👍
BMW 540i 2002
S70 Base 2000
dobrosailor
Year and Model: 2002 Vovlo C70
Has thanked: 5 times
Post by dobrosailor »
Just wait till you get to those two bolts that hold the water pipe on the back of the head by the timing belt end. Worst bolts on the entire car! Especially when you put them back in, before you install the head, glue the gasket to the head or pipe with gasket sealer and let it dry. Prepare to cus swear and think about putting a gass soaked rag in the tank filler with a lighter and run.
I did one last year, normally I start the car with fresh water run it fix the leaks if any then drain and refil with coolant. I ran it - ran great, drained the water and the next day after an overnight freeze, when I went to put antifreeze in turns out there is a little corner of the block that doesn't drain, splt the block right across the water pump seal. Car is junk now... Sigh Do not make the same mistake!
wizechatmgr
@Abscate - know anyone that can get us a ~1" thick steel plate cut to just larger than cylinder head size? I can tear that head down (valves and valve seals) and cook it.
Charcoal or Propane? I usually like charcoal as it gives that tasty flavor. I have no doubt this topic is as controversial as which oil is the best for a P80 =P
I'll check my oven at home. It's gas and may do the 500F. Need to clean it anyways, so no harm there. Downside is the head may smell like burnt smoked food. No licking it... =P
Been thanked: 4065 times
I’ll have to talk to STS steel, they have some scrap laying around I think...
I’ll just grab a piece of this 3 inch
