I'm dying to put that head on top of the grill though =Pabscate wrote: 21 Feb 2020, 20:40 I’ve got deep brinnelling andvalve issues too, so I think one has shuffled off its single mortal coil.
1998 V70NAM56 (NOW ENGINE SWAP) , winter 2020 "The Orange Mountain"
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
- Has thanked: 316 times
- Been thanked: 531 times
Yeah, I kinda want to see the head on the grill now.
- Has thanked: 311 times
- Been thanked: 817 times
agreed. something like this:
<<<brats>>>
|===head===|
<<<brats>>>
|===head===|
- wizechatmgr
Apparently it isn't fully taboo...
https://www.enginebuildermag.com/2014/1 ... ightening/
- RickHaleParker
- Been thanked: 978 times
Active
Past
Past
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
There you go, had several heads done this way, but not with a fancy oven like that. Regular backyard bbq big enough works just fine
BMW 540i 2002
S70 Base 2000
dobrosailor
- Year and Model: 2002 Vovlo C70
- Has thanked: 5 times
Just wait till you get to those two bolts that hold the water pipe on the back of the head by the timing belt end. Worst bolts on the entire car! Especially when you put them back in, before you install the head, glue the gasket to the head or pipe with gasket sealer and let it dry. Prepare to cus swear and think about putting a gass soaked rag in the tank filler with a lighter and run.
I did one last year, normally I start the car with fresh water run it fix the leaks if any then drain and refil with coolant. I ran it - ran great, drained the water and the next day after an overnight freeze, when I went to put antifreeze in turns out there is a little corner of the block that doesn't drain, splt the block right across the water pump seal. Car is junk now... Sigh Do not make the same mistake!
- wizechatmgr
@Abscate - know anyone that can get us a ~1" thick steel plate cut to just larger than cylinder head size? I can tear that head down (valves and valve seals) and cook it.
Charcoal or Propane? I usually like charcoal as it gives that tasty flavor. I have no doubt this topic is as controversial as which oil is the best for a P80 =P
I'll check my oven at home. It's gas and may do the 500F. Need to clean it anyways, so no harm there. Downside is the head may smell like burnt smoked food. No licking it... =P
I’ll have to talk to STS steel, they have some scrap laying around I think...
I’ll just grab a piece of this 3 inch
- 9 Replies
- 2455 Views
Last post by wizechatmgr
- 1963 Views
Last post by foggydogg
- 35 Replies
- 17068 Views
- 14 Replies
- 5876 Views
Last post by V70r carbon
- 9 Replies
- 3244 Views
Last post by BlackBart
