To do pictures click on Full editor (below) and use the picture functions.
You can attach the picture or link to one hosted on another website.
MAP Sensor location Topic is solved
- RickHaleParker
- Been thanked: 978 times
Active
Past
Past
- RickHaleParker
When I search with a B230F configuration, the part number does not come up. No engine pressure sensors come up for a B230F configuration. B230K configuration ... yes as shown above.
Active
Past
Past
MALL240
- Year and Model: 1991 240 2.3 turbo
- Has thanked: 28 times
OKKKKKKKK that's it. thanks a lot RIck!! I was going mad... i will return the piece... maybe my idle problem and hesitasion acceleration only in stopto run its from the regulator pressure ... its expensive, i will going to check if it clean and dry...
Thanks a lot guys!!!
- RickHaleParker
Not that much detail.MALL240 wrote: 25 Feb 2020, 01:19 Maybe if we found de rubber tube that go connected to the manifold?? in your program? Can´t find it..
B230F or B230FT (Turbo) ?
Active
Past
Past
- RickHaleParker
If you have a lot of kilometers on the car keep this in mind. A replacement fuel regulator does not need to last forever, it just needs to out last the car. You can get after market fuel regulators for about € 50.00 .
Active
Past
Past
- 5960 Views
Last post by HMP12
- 2358 Views
Last post by jimmy57
- 676 Views
Last post by PaulMartin
- 5010 Views
Last post by tflesui
- 2186 Views
Last post by Ville1121
