Back when I got my car in the summer, I replaced the entire PCV system before driving it due to some popped out cam seals indicating a problem with it. I used the IPD kit, all went well, I did the glove test afterwards, and it never did suck it in, nor did it fully inflate it. I also connected a long hose to the dipstick and a pressure gauge that will read as low as 0.5psi, drove it under full throttle, and never read any pressure. 10,000KM later with the PCV system connected as factory, no issues with dipstick popping out, or any leaks, even from oil cap. The only issue I have had is oil leaking from the air intake pipe clamp on the turbo inlet, due to oil pooling there from the PTC vent there, which is as clean as new. I'm trying to see if my bevel gear is leaking there, and the turbo dripping on it makes that hard, so I ran vents to atsmophere from the large PCV hose to the PTC and from the dipstick, after driving, both were full of milky oil/water that froze to the underbody in a long icicle, and can see white smoke coming out after a 85KM highway drive at idle. I'm not loosing coolant, level has not dropped in the 10,000KM I have had it. Is it possible my oil seperator is not working as intended, or another issue? I never removed the oil pan to clean passages in there, I just blew into a hose into the drain of the PCV seperator in the block, and if freely flowed into the oil pan.
I guess coles notes, I seem to be getting alot of oil/water in my intake due to the PCV system, could my IPD PCV seperator not be working correctly?
Defective new PCV?
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
When you say IPD PCV separator - do you mean a Volvo branded one bought from IPD?
Reason I ask is there has many many many issues with aftermarket items just not working correctly. If it's a 3rd party catch can, try removing it and cleaning it with solvent, then checking again. They clog up, just like the Volvo one.
2023 Lexus RZ450e -66k
- Has thanked: 312 times
- Been thanked: 818 times
Does this car see mostly short trips around town, or does it get fully warmed up most times?
- befarrer
- Year and Model: 1998 V70 AWD
- Been thanked: 24 times
Oops, sorry, I meant URO kit. Im in Alberta, so temps have been always below freezing, most of the trips are under 30 minutes. I do a long highway trip of about 1 hour each way every 2 weeks or so. Im parking the car for a few months this weekend as I go back to school, my primary result from this was to get rid of an obvious oil leak to see if I have another oil leak in the same area, so I could tackle it while the car is parked. But if there is another issue with the PCV box, I could tackle that at the same time.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
05 VW Golf TDI
- Has thanked: 1611 times
- Been thanked: 4075 times
We are not big Fans if URO parts that see oil, fuel, ATF, brake fluid, coolant, power steering, or vacuum - other than that, they are fine.
- Has thanked: 2210 times
Never ever use Uro branded pipes. Having spent ages cleaning and replacing the PCV system with a kit from IPD years ago, the short 'J' pipe from the side of the catch can to the middle of the block split after 700km. IPD stopped using URO parts after 2 other customers had the same issue around the same time. They refunded the part price and I used a Volvo part, but naturally cost a lot in time and extra money as the inlet manifold had to come off again to replace it.
- RickHaleParker
- Been thanked: 980 times
Hey guys go look up the word Uro in a dictionary. Uro describes Üro Parts to a tee.
Active
Past
Past
Too true!
- 792 Views
Last post by ZionXIX
- 2113 Views
Last post by oragex
- 360 Views
Last post by JaredR
- 879 Views
Last post by cBobs94850T
- 1326 Views
Last post by tryingbe
