Familiar "burning engine" smell returns
Jibbaman150
Year and Model: 2005 xc70
Post by Jibbaman150 »
Hi everybody. So I have put about 3500 miles on my 05 xc70 since I rebuilt the head for a burnt valve (cylinder #4) For the first 2000 miles there was ZERO oil consumption. Recently I have been adding some(not more than a quart) Going up hill I get a burnt rubber/oil smell. The same smell that has preceded burnt valves in 2 different xc70’s I’ve owned...Yes the PCV system FAILS the glove test. However it was replaced 8,000miles ago and of course cleaned/inspected when I replaced the head 3,500miles ago..So am I looking at dropping the oil pan to replace the lower part of the PCV? Should I just plan on having to replace or clean my PCV every other oil change? 104,000miles on car. Thanks for reading.
Has thanked: 1609 times
Been thanked: 4065 times
I could be the oil port wasnt cleaned on the PCV job, or bad parts were used.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
I vote for a hole/crack in exhaust. Did you replace exhaust manifold gaskets? Also the nuts can slacken there, may need another torque to spec.
ignatz
Year and Model: 2006 S60 t5m
Has thanked: 18 times
Been thanked: 33 times
Post by ignatz »
Or maybe engine compression is leaking back into the crankcase. Check compression and look for an oily or darker plug. I'd make sure the top end is good before you go forward with other repairs.
Did it ever pass the glove test?
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
Jibbaman150
Ok thanks this has got me thinking. The PCV system was from Volvo and wasn’t that dirty when I took it apart and cleaned it. The port on the side of the block was cleaned. I am unfamiliar with the lower part of the system(the part that goes into the oil pan) Compression test after I completed the head rebuild was 145 in cylinders 1-4 cylinder 5 read 130..I had a tuff time using my cheap harbor freight tester. Could my rings be worn? I don’t think it’s the exhaust mani, yes I used new gaskets/seals all Volvo brand blue box stuff. It failed the glove test right after I got it back together. However it didn’t smell like it was burning oil or a valve or whatever that smell is until a few thousand miles later. Thanks for the thoughts guys.
vtl
Post by vtl »
My 05 has engine w/ 223k miles, PCV develops a good vacuum at idle. Under boost it has some positive pressure, that started in less than 2 years. I.e. no crankcase problems for 13 years and 200k miles.
Engine is pretty much cooked if a good, newly installed PCV can't get a negative pressure in crankcase at idle.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Did you replace the hose that runs from the breather box up to the top of the engine? They like to split open just above the breather box and exhale an oily smell.
Also, when you serviced the PCV system, did you replace the little nipple fitting that attaches up under the intake manifold?
vtl
Post by vtl »
Every single bit was replaced. Twice in 120k miles, in fact.
Banjo bolt (the nipple) I replaced one more time just a week ago or so, because I could not figure out what revision it was when PCV was replaced last time. Turned out, the latest, and it was not clogged: the check valve was pressuring PCV from manifold when it had boost.
Because positive pressure happens under boost, I installed an oil catch can using 14 mm ID silicone hose, plus drilled PTC nipple as much as possible. Idle vacuum is worse now (it sucks more air from intake before the turbo), but should be better under the boost. I hope.
Jibbaman150
All of my hoses were in good condition. The cylinder head was off so I of course cleaned everything including the ptc nipple. I guess I’m going to order the PCV kit and have it on hand while I get in there to inspect everything. Anyways here’s some pictures from the last time I had her apart
vtl
Post by vtl »
What a clean head! I'm planning to boil mine in dimethyl sulfoxide to dissolve carbon that seems to be everywhere in donor engine.
