The latch lock has two parts the first is to be able to unlock the mechanism. This can be done by either the key in the back (Mechanical) or the fob or release button on the driver side door. This is electrical through a solenoid on top of the latch.
Them to open the hatch you can either depress the paddle under the outside handle n the middle above the license plate or with a handle inside the door also kind of in the middle under the window.
Either one of these two actions then press on a plate below them. My question is if the unlatching is then done mechanical or electrical?
1998 V70 XC Hatch lock
Unlocking electrical by solenoid
Unlatching’
Mechanical on a V70
Electrical on an S70
Unlatching’
Mechanical on a V70
- Has thanked: 311 times
- Been thanked: 817 times
If you can't get the tailgate open, you can crawl in the back and release the latch receiver loop from the body with a large (T45?) torx, two bolts. Then open it up, remove the tailgate trim and remove the latch to replace it.
- 270 Views
Last post by SonicAdventure
- 895 Views
Last post by erikv11
- 854 Views
- 655 Views
Last post by VolvoChef
- 614 Views
Last post by Steve H
