Any good 850 techs out there? Got a challenge for you
Pumpkinmikey
- Year and Model: 96 850 non turbo
Well today I rechecked compression.cleaned plugs AND she started right up..smoked like pig but ran perfect. Same thing as last week.runs perfect if it starts..does anybody know the test value of crankshaft sensor??? That is the only other thing I touched today.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Did you check your ECT sensor connector yet?
Seriously, check it/clean it.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
What about main fuel injection relay?
Did you checked it's connection?
It's the grey one VOLVO on the fan shroud.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Pumpkinmikey
Yes cleaned ect connector.it was nasty and rubber inside goo. Cleaned good continuity resistance varies with temp.but it still no run
..today fired up running better than it should. Scared what happens in a.m.all I did was recheck compression and valve timing..cranked right up ??? I did have a priest in my car when I drove past..heehee
- misha
Could be that cranking,when you re-checked compression,cleared the excessive fuel from cylinders.
Could be that it was just flooded.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Pumpkinmikey
I have been fighting this thing for a week. Pulled and cleaned plugs 4 times.flushed fuel sys. New gas.92.
tardcart
- Year and Model: 96 850t. 93 940t
- Has thanked: 3 times
- Been thanked: 37 times
clouds of smoke that's not black indicate not fuel related. you have a bad head gasket letting oil or coolant in to the cylinders. you have to give more info on coolant level and if this car is on the road or only started when you tinker with it.
- RickHaleParker
- Been thanked: 979 times
Keep doing the same thing over and over until you get different results.
Active
Past
Past
- 800artfreed
- Year and Model: 98 S70T5; 99 S70GLt
- Been thanked: 26 times
Any solution to your problem? Thanks.
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
- Been thanked: 4068 times
2 years since OP checked in. You seldom learn anything from the “ humming bird on meth” approach to troubleshooting
