T45 torx bit
neilpatstone
Year and Model: V70 gtl
Post by neilpatstone »
Hi I need to remove the timing belt tensioner, it has a T45 torx bit but it needs to be very short, I can find them in America but not here in Portugal or the UK, if anyone has any other suggestion of how to remove the pulley or where I could purchase one that would be great, many thanks Neil
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 53 times
Post by callahanoffroad »
I'd suggest amazon
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
A mechanic friend taught me that he buys several sockets of the same size so he can modify them for specific jobs. He grinds the bit end a bit shorter and the ratchet end a bit until it fits.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
If there’s room, sometimes a box end wrench
the same size as the bit can work in tight spots.
Has thanked: 311 times
Been thanked: 817 times
I use an L-shaped torx for that, it works really well if you slip a thin pipe over the long arm to extend the torx lever up to the top near the timing sprockets. It is important to lever the bottom of the wrench into the T-45 hole at the same time. I use a flat prybar with my other hand. This has always broken them free, without hassle.
Even a cheap L-shaped torx works from me, from an inexpensive kit with several in the set.
Be careful to not strip out the torx recess.
L-shaped torx wrench
L-shaped torx.jpeg (9.4 KiB) Viewed 1451 times
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Bondhus 31845: T45 Torx L-wrench - Long Arm (Carded) on eBay US. You might find one on Ebay eBay Portugal.
It is 5.4 inched long. You could slip a cheat bar over it for mechanical advantage.
Active
Past
Been thanked: 4065 times
You can also sometimes use the bit without the handle to fit in that space. A box end wrench (19mm?) slide over the bit to turn it then
Bmdub has a nice picture of that if needed, post request here.
