1998 V70NAM56 (NOW ENGINE SWAP) , winter 2020 "The Orange Mountain"
- callahanoffroad
- Year and Model: 1995 850
- Has thanked: 16 times
- Been thanked: 53 times
Glad you had to do this before me! I'll let you figure out how not to do it and then glean that info for my own benefit! Thanks Abscate!
- Has thanked: 1611 times
- Been thanked: 4072 times
UPdate
Sourcing new engine - can you guys help me Swag this out?
Engine out -(head already off, disconnects done ???HOURS
Engine rework ????? HOURS
Swap water pump, timing gear
PCV evaluate swap
Engine replacement ???HOURS
Ive got a lead on a $650 engine with good history local.
PCV evaluate swap
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
When I was contemplating the same procedure I was told pretty universally that the head re-work was 15 hours labor and the engine swap was 18. I can't imagine that has changed.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Has thanked: 2209 times
Dealer charges 10 hours for rear main seal replacement so Evan's estimate is good if you do little else other than out with old and in with new. Based on the time, if you have to do this then if you have a lead on a known good running engine with history that is a good start. question, would you do all that work without a timing belt, rear main, trans inner seal?
Neil
Neil
- Has thanked: 316 times
- Been thanked: 531 times
You can have the good running '98 NA engine sitting in my garage for cheap... only has 270k miles. Runs like a top!
Only problem is the location...
As far as hours for an engine swap, including a basic PCV and timing belt job on a '98 NA, I would say 12-14 hours if you're really working hard. My cousin and I pulled the aforementioned engine in about 3 hours, and it probably took me about 4 hours of work (or less) to get the engine into my S70 and running after doing the refresh work (oil pan seals, PCV, timing belt, cam/crank seals, cam cover reseal, etc.), which probably took another 5-6 hours. I was able to pull the old engine from my S70 pretty quickly since it was the same situation here, I pulled the head anticipating redoing the head, but heavy corrosion on the cylinder walls made the ultimate decision for me.
- 9 Replies
- 2477 Views
Last post by wizechatmgr
- 2000 Views
Last post by foggydogg
- 35 Replies
- 17227 Views
- 14 Replies
- 5902 Views
Last post by V70r carbon
- 9 Replies
- 3268 Views
Last post by BlackBart
