Vida dice driver download?
XC60aches
Year and Model: 2015.5 XC60
Post by XC60aches »
Anyone have a good link for Vida dice drivers?
Thanks
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
On the Vida DVD:\3PP\Products\DiCE\SetupDiCE.exe
Active
Past
XC60aches
Post by XC60aches »
Thanks.. no dice... literally:-)
Plug in usb ... no device found.. unknown device (invalid USB device descriptor)
Windows stopped device because it has reported problems (code 43)
Tried all three USB ports... same result
rebooted.. same result.
uninstalled driver. Seems to be using generic type driver... rebooted.. tried updating... same result
Different USB cable.. same result
RickHaleParker
That error code is a windows problem.
Workable Solutions
Fix 1. Restart Your Computer.
Fix 2 Try every USB port available.
Fix 3 Determine what USB version: USB 1.X, 2.X or 3.X. DiCE requires 2.0 or higher.
Fix 4. Fix the Device Driver: Update, roll back, reinstall the device driver.
Fix 5. Re-enable the Device: Go to the "Driver" tab and choose "Disable Device" > "Enable Device".
Fix 6. Fix the USB port drivers: Update, roll back, reinstall the USB port drivers.
Fix 7. Update BIOS: Go to download the BIOS update file and then update your BIOS.
Fix 8. Restore System: Open "Control Panel" /"System" /"System Protection" on the left panel.
Active
Past
XC60aches
Post by XC60aches »
Thanks again..
Updated bios but don’t suspect that will fix
I have up to usb 3.0 (one port if remember correctly.. unsure which one, but tried them all.
It’s a fresh install of win10pro.. literally all I have done is WiFi connection and installation of VIDA.. so I don’t think restoring would do anything
I will try this additional stuff tomorrow..
Thanks again
I will try the disable/enable swap
RickHaleParker
XC60aches wrote: 04 Mar 2020, 20:15 It’s a fresh install of win10pro.. literally all I have done is WiFi connection and installation of VIDA.. so I don’t think restoring would do anything
If it is a fresh install, it very well maybe the drivers for the USB controller.
2020-03-04 (1).png (175.35 KiB) Viewed 26322 times
Active
Past
XC60aches
Post by XC60aches »
Appreciate the assist Rick. Yes the USB controllers is exactly where I am getting the errors.
Just so you know, this is an old toshiba laptop. It was purchased with windows 8.1. I installed windows 10 64-bit pro on it. Win 10 is not a toshiba specific image... but never had any issues.
It seems this dice doesn’t like my USBs to much. Tonight with dice plugged in, I will uninstall the usb controller drivers, reboot.. see if reinstalls any better. I think it will reinstall the same.
You think I can force manually install the windows 7/8 USB 3.0 driver (available on toshiba website) and it might work?
XC60aches
Post by XC60aches »
Bios updated.. same result
Flipped disable/enable.. same result
Removed all usb drivers.. rebooted.. same result
Would not manual install win7 usb 3 driver
Went into bios and turned off usb 3.0 controller.. same result
Not for sure what to try..
RickHaleParker
XC60aches wrote: 05 Mar 2020, 17:29 Not for sure what to try..
Go to the Computer manufacturer's website and find the support page for your model. Download the drivers for the USB controller and install.
While you are at it you might as well get all the correct drivers.
Active
Past
XC60aches
Post by XC60aches »
Good put.. I’ll do that. I probably won’t get a chance tonight to try it..
I also will try those USB images from the other site. Had them before and deleted. I knew it worked at least to get into Vida, but had preferred to have it installed. So they are downloading...
Again.. appreciate the tips...
